Laminate At Base Of Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 01:22 PM   #1
Laminate at base of stairs
I'm new to the forum AND to DIY-ing in general, so if I sound like an idiot, it's because I'm learning.
I have several different types of flooring on the first floor of my house - carpet, parquet, and vinyl tiles. I'm currently replacing most of it (all but the kitchen) with Pergo Casual Living laminate. It's been relatively easy so far, but right now I'm trying to do the area in front of/around my staircase.
A single plank is about two inches wider than my staircase.
Is it better to cut one plank to fit in front of the stairs, fitting up against the bottom step and the spindles, and wrapping around about an inch on each side of the staircase? Or would it be better to use two planks, so that there's more plank on each side of the stairs? I'm concerned about having a joint so close to the wall on each side, and I'm worried about having a tight fit with a single plank.
Or is it just six of one and half a dozen of the other?
Any advice is greatly appreciated!
daisychain is offline   Reply With Quote
Add stairs to cement base Lexiesmom Landscaping & Lawn Care 4 11-20-2010 07:06 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
screening as a base for stairs. rabih_00 Landscaping & Lawn Care 5 09-25-2008 11:21 AM
Putting laminate floors upstairs..what should I do with my stairs genyaf Flooring 4 01-02-2008 10:52 PM
HELP - laminate on stairs mf915 Flooring 6 07-11-2007 10:12 PM
