Old 10-16-2009, 01:36 PM   #1
Lake Forest, CA
Default Laminante wood flooring layout opinions needed.
Howdy folks,
Armstrong Laminate flooring. Glueless/Floating http://www.armstrong.com/flooring/la...oor-104118.asp
I got a quick question about laying out my flooring.. I intend to start out at the "top" wall in the photo and work my way to the bottom of the photo.. This will mean that the planks will be perpindicular to the length of the joining hallway.. Is it wrong to do this or should I try to do some sort of transition from the main rooms to the hallway so the planks are perpindicular to the length of the hall? The floor plan below is not to scale or true layout but close.. The hall in the picture appears a bit longer than it really is... The gray area on the left is the kitchen.. The gray area on the right is an elevated entry way so there is no wall there. Both gray areas are tiled.
Another general question I have... Is it possible to lock/join the end of a plank with the side of another.. In other words, join them perpendicular to change directions of the flow. I know you can do this with a T molding but those would not be ideal in my opinion. I am waiting for product delivery so I haven't seen how the end joints are constructed.
Thanks in advance for any assistance.
Cheers,
Jerid
SKINNY is offline   Reply With Quote
Old 10-18-2009, 02:54 AM   #2
Lake Forest, CA
No takers?
Old 10-18-2009, 02:44 PM   #3
jtpro's Avatar
It's your personal preference as to the "how" you lay it out. My house has real red oak from the 40's and it's layed out the way I've seen and done flooring.
I would run it Parallel with the hall walls from the top wall to the bottom and tile around the fireplace.
I know it looks like a third grader but I don't spend money on software for this kinda stuff.
Hope that helps.
jtpro is offline   Reply With Quote
Old 10-19-2009, 01:51 AM   #4
Lake Forest, CA
Thanks for the reply jtpro.
I think your recommendation would look good whenever moving from one room to the next through the hall however I think it would break up the flow when entering through any door on the floor.
Here are a couple examples.. again, not to scale.
More On This Topic
So our next pose we're going into is the plank. Start it in mountain, inhaling up, reaching up and back, exhale, pitching forward, flat back all the way down into a standing forward fold. From this position you want to soften your knees until your hands... Read More »
Sun Salutation Yoga: Plank
Sun Salutation Yoga: Plank by Expert Village
We are going to move to a one legged plank. This is not necessary, it is not like you are going to be the perfect yoggi. If you can do a one legged plank. It is just for fun, it is just to built more strength. You can work toward this. So, Onica is going... Read More »
Living in a college dorm can be the perfect opportunity to meet people and make new friends. You and your dorm mates will be experiencing the upcoming semester together, so use these tips to get out there and meet the people with whom you are going to... Read More »
Hi! This is Manny Castro, Exercise Physiologist. In this exercise, we want to demonstrate a plank. Now if you are familiar with this type of exercise, there is a plank, which you do without ball. Obviously, with the ball, it is going to be much more... Read More »
Alright, moving forward in our sun salutation sequence for strengthening the upper body, we're getting to the big time. We've already come through our tadasana and we're here in our forward fold. So we're going to hop back into plank pose. You can either... Read More »
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 01:19 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 11 07-13-2008 11:04 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 11:14 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 5 07-07-2008 10:33 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 08:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
