Laminant Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 05:57 PM   #1
laminant transition
beat way to screw transition to concrete floor, track n/a, real wood...thanks
tatanka is offline   Reply With Quote
Old 08-07-2012, 07:44 PM   #2
Rewards Points: 13,250
What type are you using?
The ones made by the same companys that make the flooring most often include plastic anchors, and use a metal stip that gets attached first.
Just use a masony bit and drill a hole with a hammer drill, vaccum out the hole and insert the anchor.
Old 08-07-2012, 10:57 PM   #3
laminant transition
thanks, my trans. strip is 3/4 oak & not desighned for track. I guess that dowel & screws is my only choice w/ dowel buttons. Thanks
Transition from Vinyl to Wood Question petros151 Flooring 3 02-16-2012 12:42 PM
door jamb cut over transition rtoni Building & Construction 4 10-28-2011 04:50 PM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 01:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 03:19 PM
