Laminant Flooring Question - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2010, 01:52 PM   #1
Laminant flooring question
I have researched my flooring and they require an expansion joint after 21 feet. My room is 28' x 20' in an L-shape. I was originally going to run the planks parellel to the longest wall (28') thus I would need an expansion joint. As a result I wanted to run the planks the other way thus my longest run of planks would be 20' and not require and expansion joint. My question is, do I still need an expansion joint between the planks that are running vertical from the longest wall. I hope I explained that right...thanks
mort5029 is offline   Reply With Quote
new construction flooring question bgabrielse Building & Construction 5 12-05-2010 05:52 PM
Subfloor flooring for hardwood (question) somaxim Flooring 0 11-11-2010 05:29 PM
Hardwood flooring expansion question Richo Flooring 0 08-23-2010 12:05 AM
Question about linoleum flooring JZ2008 Flooring 2 02-24-2008 08:59 PM
sub flooring removal question matchley Flooring 7 10-02-2007 09:19 PM
