Laid T&g Pine Flooring And Now Need To Sand It - Flooring - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 07:56 PM   #1
laid t&g pine flooring and now need to sand it
because its a soft wood, i'm afraid. i had posts a while back but was getting ahead of myself and cant find them now. can i use a small orbital sander so i don't take a bunch of wood off? and i want to use an oil base polyurethane after. what grit to start? 150? to 220 thinking.... i called about renting and they only have 100 grit, seems too rough.
brenda o is offline   Reply With Quote
Old 12-02-2009, 10:28 PM   #2
DIY staff
Rewards Points: 7,174
Brenda, I suggest that you use a 4" hand held belt sander --if the floor is not to large.
A4" belt sander will quickly flatten and smooth out a fresh pine floor.
The machines take a bit of learning--You have to keep them moving constantly. Not hard to learn.
They are a pricey machine to buy--They can be rented,however.
Don't be to tempted to buy the much cheaper 3" one. You need the larger foot print to get the floor flat and smooth.
A random orbit 5" sander would be my suggestion for edges. They are much much faster(and the sand paper lasts a lot longer)
Start with 150 grit--Move up to 200 or 220 for the final.
Good luck,have fun---MIKE----
Old 12-02-2009, 10:29 PM   #3
Yes, pine is soft so you'll need to be careful. With little to no experience, I'd recomend you go to Menards or some other big box store that rents sanders & rent a 3 or 4 hear random orbital sander. It's very novice friendly & should work very well on the pine.
You're going to start with 36 or 40 grit paper & work your way down to 100 grit. 100 is for sure fine enough. 3 coats of poly on top & you'll be good to go. As you get ready to apply the finish & have more questions, be sure to speak up.
pinwheel45 is offline   Reply With Quote
Old 12-02-2009, 10:41 PM   #4
DIY staff
Pinwheel and I must have been typing at the same time!!! HaHaHa--Beat you by 30 seconds--MIKE--
Old 12-04-2009, 12:25 AM   #5
the sander that both of you
mentioned was the random orbital one. I do have a 3 in belt sander already but didn't think that was a good call. The belt shifts so easy on me. I'll check on the orbital though. Thanks, going for the gusto... i even started it with my palm sander.... thatsssssss work!!!
