Old 06-13-2009, 05:52 AM   #1
Konecto vinyl plank floor
We had a friend install Konecto vinyl plank flooring over our existing sheet vinyl and very pleased with job and appearance. A month later during a quick warm spell in April the floor buckled and after investigating a section of the old sheet vinyl has come up from the sub-floor. Lesson learned we should have removed the old vinyl but are there any tips on how to cause the old vinyl to lay back in an effort to avoid removing the new vinyl. The bubble is roughly a 2' x 2' area and it is an old farmhouse where floors are not very level. Furthermore in another 5 to 10 years we will likely remove all and install real wood floors. So I am just trying to get the floor to lay down and avoid the expense of ripping up brand new vinyl plank floors. Any suggestions would be appreciated.
john deere b is offline   Reply With Quote
Old 06-13-2009, 07:22 AM   #2
the Musigician
DangerMouse's Avatar
perhaps setting a 3x3' piece of sheet plywood, osb, etc. and putting a heavy weight on it for a few days might help?
just a thought...
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-13-2009, 01:20 PM   #3
Floorwizard's Avatar
that's the only thing I can think of too.
Floorwizard is offline   Reply With Quote
Old 06-13-2009, 01:27 PM   #4
the Musigician
go grab Gramdma's old steamer trunk out of the attic?
at least you won't have to look at a toolbox on the floor on a piece of plywood.... lol
leave it there a few weeks and see if it helps?
tell the kids whatever they do, don't stand on that piece of plywood over there?
DM
I want to install laminate plank flooring but have problem with sub floor In the Bush Flooring 3 04-29-2009 01:35 PM
no glue vinyl floor (armstrong) kirtland Flooring 8 04-30-2007 12:14 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
