Konecto Tile Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 06:43 AM   #1
Angry
Konecto tile floor
We bought the Konecto tile floor to put in the basement because we didn't want to have glue down on the concrete. We followed the instructions to the letter. The whole floor is lifting. Does anyone have any suggestions
Drudnns is offline   Reply With Quote
Old 06-06-2013, 06:49 AM   #2
DIY staff
Rewards Points: 7,174
Did you leave enough room for expansion at the edges?
I don't know anything about that product--but if it can expand like most flooring--and bumps into the wall when it does---the flooring will 'balloon' off of the floor.
Old 06-06-2013, 06:53 AM   #3
Yes, my husband installs flooring for a living. It is a beautiful floor 16 X 16 tiles with a adhesive edge to lock them together.
Old 06-06-2013, 08:57 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 92
If he installs for a living, he should be aware that Konecto is not a good product. It has many failures.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-06-2013, 09:48 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 346
There could be several reasons for the failure.
To start with, I think it's a waste to spend your good money on that type of product, and that goes 2x for a basement.
The basement may be too damp. Did you do any type of moisture test first? The floor may not be perfectly flat. May have been installed too tight to the wall or trim. What is the temp of the concrete? The instructions specifically tells you not to install if the "environment" is ever below 65 or warmer than 85 degrees. That a ridiculous stipulation.
It would be helpful if you had included more info such as where you're located.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (06-07-2013)
Old 06-07-2013, 04:59 AM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Konecto has a really bad track record. Installation must be perfect and it still tends to have issues with peaking at the seams. You need a perfectly flat floor, no excess moisture, proper expansion gap, you must hand roll each seam as it's installed, you must full roll the entire floor after installation, and make damn sure you don't get even one spec of dust on the adhesive strip during installation.
Darkling Designs
poppameth is offline   Reply With Quote
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Porcelain tile over linoleum floor Jac121 Flooring 11 01-06-2012 07:32 AM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 12:07 AM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 09:41 PM
