Konecto Curling - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 04:19 PM   #1
konecto curling
I have konecto installed in a house that was cleaned with Old Englsh. The floor is starting to come apart at the seems. Could the Old English be the cause of this?
ramsco is offline   Reply With Quote
Old 04-28-2011, 06:10 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
Haven't heard that one before. Check out Konecto in the search box. Not unusual to have seam separation.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-28-2011, 06:12 PM   #3
woodman58's Avatar
I would say it is not the fault of the old english. It would take a lot of moisture to in the seams and break down the glue. If you installed it yourself call who ever you purchased it from and ask them to come and take a look. Do not tell them that old english was used. Most product suggest using only water. If you had someone install it have them come and take a look at it.
woodman58 is offline   Reply With Quote
Old 04-29-2011, 05:50 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Konnecto is prone to such problems anyway, but if it only occurred after using the cleaner, I'd have to say yes that is probably the cause of it. Never use products like that on a vinyl floor. Old English has citrus oils in it. Those oils can damage and stain the vinyl as well as seep into the joint and dissolve the adhesive that holds the planks together. Konnecto already has issues with the adhesive system. This is just making it worse.
Darkling Designs
poppameth is offline   Reply With Quote
Old 04-29-2011, 12:22 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
How was it cleaned? There is a big difference between wiping it with a damp sponge and wet mopping it.
Other Konecto Products for Kitchen jamiedolan Flooring 4 06-04-2010 05:56 AM
Konecto flooring LookoutRanch Flooring 23 03-08-2010 03:32 PM
Konecto flooring failure/Don't recommend shredlew Flooring 160 07-07-2009 11:40 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Konecto Flooring 26yrsinflooring Flooring 30 10-27-2008 08:26 PM
