Knots Is Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 08:22 PM   #1
member
knots is wood flooring
I live in south west LA. I have just purchased dried 8" t&g cypress lumber for flooring. I purchased #2 lumber and love the look but do have knots that will need attention. I don't want them poping out later. It is 3/4" thick material. I am thinking of no stain but oil based poly for the amber color. Any suggestion would be helpful, it will be nailed down to sub floor in 100 year old home. I am a DIYer and first time with wood flooring.
oilfieldjack is offline   Reply With Quote
Old 02-03-2013, 10:30 PM   #2
Rewards Points: 264
Thats a good choice of flooring. It should look nice. Since it is this wide you should probably nail and glue it. I would also allow it to acclimate in the house for awhile.
Awoodfloorguy is offline   Reply With Quote
Old 02-03-2013, 11:12 PM   #3
member
thanks for the reply, I have been told that it is a good choice but it is a soft wood for flooring. It is in the home and I will install next week. Do you have any reccomendations for the finish.
Old 02-03-2013, 11:14 PM   #4
member
anyone has any reccomendations for an epoxy to treat the knots before sanding and finishing.. thanks
Old 02-03-2013, 11:17 PM   #5
Rewards Points: 264
Its been awhile since I had to do this. But if I remember right 3m had an epoxy for this.
Old 02-04-2013, 07:48 AM   #6
woodman58's Avatar
If the knots are tight you will have no problems. If they are loose you can use Cyanoacrylate (CA) to secure the knot. CA is super glue. I use this strengthen soft and punky wood before turning on a lathe. Just saturate the the knot and allow to dry.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 02-04-2013, 07:59 AM   #7
DIY staff
Rewards Points: 7,174
If you have good boards with loose knots---either cut the boards shorter to remove the section---or use a router to remove the knot and install a patch---
Google 'router inlay' for an idea how this is done-----
You need a set of rub collars for the router----a 1/4" straight cutting bit---and a home made template----all inexpensive parts---( a band saw is handy for removing the repair plug from the scrap wood--but is not a 'must have')
I have a variety of free form openings in my template and match up the opening that best fits the area to be removed==
I use this to salvage a good board with a knot or flaw on a regular basis---
Once set up each knot only takes a couple of minutes to remove and patch.
engineered wood flooring nailer joshanah Flooring 3 06-04-2012 11:21 AM
Vinyl flooring over wood slat subfloor Patricia54 Flooring 6 02-11-2012 02:22 PM
Electric Outlets under wood flooring jeh154 Electrical 3 08-09-2010 10:05 AM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 06:50 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
