Kitchen Underlayment Questions For Porcelain - Flooring - DIY Chatroom Home Improvement Forum
Old 11-10-2008, 01:35 PM   #1
Kitchen underlayment questions for porcelain
Hi everyone,
I am planning on having porcelain tile laid for my kitchen floor & was wondering if anyone had recommendations regarding underlayment. I am on the 3rd floor of a condo building & my subfloor is a concrete slab (not sure of its thickness).
For my LR & BR I am planning on using floormuffler under 3/4" advantech as underlayment for a strand woven bamboo floor, but I know that kitchens are a different ballgame (so to speak).
Thanks to everyone here!
eis61374 is offline   Reply With Quote
Old 11-10-2008, 01:38 PM   #2
RippySkippy's Avatar
Ditra.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-10-2008, 01:52 PM   #3
Thanks Rippy, is there any sort of insulation &/or underlayment that is recommended to be put down first? Or should the ditra be laid directly on top of the concrete?
Thanks for your advice.
Old 11-10-2008, 02:11 PM   #4
In a normal install, attached via thin-set to the concrete. Does your building have any requirements given you're having tile on concrete, that could be loud for the lower neighbors...
LMASD
Old 11-10-2008, 03:02 PM   #5
Ahhhhh..yes I believe the condo does require some sort of noise barrier. In that case could I perhaps lay floormufler on the concrete & then place some sort of underlayment (perhaps advantech) on top of that, similar to what I am doing for the bamboo install? From there would I be able to install the ditra/porcelain over that?
Thanks again!!!!
Old 11-10-2008, 10:39 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 218
I don't understand why Advantech is being considered in this installation? Advantech, plywood or OSB, should not be installed on a floor other than regular suspended wooden joists construction. You said the floor is concrete.
Concrete? Maybe, maybe not. Usually these floors are Gypcrete or similar, not concrete. There is a difference.
You need to figure out what it is for sure, also confirm that a noise reduction method is required, (usually is), and what db reduction factor is recommended etc. Get the facts, report back.
Jaz
JazMan is online now   Reply With Quote
Old 11-11-2008, 12:12 AM   #7
Hey Jaz how's it going?
According to the builders/developer it is a concrete sub-floor. The structure of the current flooring (that I am removing) is as follows:
*1/8" insulayment http://www.mpglobalproducts.com/insu...fications.html laid over concrete & haphazardly duct taped at the seams
-on top of that-
*Two(2) layers of 3/8" plywood laid "railroad style" & screwed together
-on top of that-
*3/4" white oak stapled at a 45 degree angle into the plywood
Are you saying the Advantech &/or plywood, osb should not be used at all when installing over concrete? or just not in a kitchen? If you mean not at all then what is your recommendation re: the proper installation for porcelain tile in a kitchen (& strand woven bamboo in a LR & BR) when the sub-floor is concrete?
Thanks for any help.
PS
Since the insulayment was installed at the time of construction, & the floormuffler surpasses the insulayment in noise reduction, I believed it would be fine. Plus it has a moisture barrier. Am I dumb for thinking this?
Old 11-14-2008, 12:07 AM   #8
Bump. Anyone? Jaz?
Old 11-14-2008, 12:46 AM   #9
Tileguy
JazMan's Avatar
Rewards Points: 218
Ceramic tiles are adhered direct to concrete or over a membrane of some type. There is no approved method to install plywood or anything similar to concrete and then expect a successful ceramic installation. There is no need or benefit to your plan to use Advantech.
You may need to install a membrane direct to your concrete if there are any cracks or joints in the concrete. Some membranes come in liquid form. There are membranes that bridge cracks, are a waterproofing and are noise reduction. Often noise reduction is stipulated in multi-family buildings such as yours. The management will tell you the specs.
Jaz
Old 11-14-2008, 01:24 AM   #10
Thanks so much Jaz. I will look into Ditra for the kitchen. Regarding wood floor installation thruout the rest of my apartment, could you explain why advantech should not be used when done over concrete? I cannot get thru the distributor.
Questions on drywal setup for hanging kitchen cabinets... ericblair Remodeling 5 07-14-2008 05:49 PM
kitchen questions mivon Electrical 3 04-15-2008 08:50 AM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 05:06 PM
Tiling my kitchen floor, couple of questions Yeti Flooring 14 03-27-2008 10:15 PM
