Kitchen Plywood Countertop Glue? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 06:51 PM   #1
Rewards Points: 200
Lightbulb
Kitchen plywood countertop glue?
Dear all, sort of new here, how are you doing?
We have a old kitchen countertop that I believe is made of plywood. The countertop was covered by a layer or thingy that I don't know what it is. See photos here:
http://yfrog.com/0jkitchencoutertoplargej
Recently on the edges that layer is starting to peel off. I wonder what would be the best glue possible to glue this back (with short set time of course, as the peeling layer has the resistance to come off, and for this corner area I can't find a really heavy stuff to put on top of it)? Should I be using Epoxy glue? Thoughts or comments? Thanks!
ohman is offline   Reply With Quote
Old 06-23-2009, 07:16 PM   #2
Contact cement.
jerryh3 is offline   Reply With Quote
Old 06-23-2009, 07:53 PM   #3
Remodeler
MinConst's Avatar
Yes contact cement. Try to carefully lift this loose section and clean under it the best you can first. You can use paint thinner. Put contact cement on both pieces (laminate and substrate. and allow to become dry to the touch then put the two together and press tightly.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 06-23-2009, 08:18 PM   #4
Floorwizard's Avatar
perfect instructions.....
good job....
anyone else find it funny they put a seam there?
Floorwizard is offline   Reply With Quote
Old 06-24-2009, 07:16 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
After the loose piece is glued back together, all the inside corners should be caulked to prevent water or spills from getting into the joints.
Old 06-24-2009, 01:52 PM   #6
Rewards Points: 200
Thanks all! You guys are the best!
my kitchen reno - complete remodel (with concrete countertop) Knucklez Project Showcase 311 07-07-2014 05:07 PM
Tile kitchen countertop and backsplash... NJMelissaG Remodeling 1 05-17-2009 09:15 PM
Expand/Contract: Glue & screw 7" x 3/4" OSB strips on top of 3/4 plywood subfloor ? iMisspell General DIY Discussions 8 05-11-2009 07:09 PM
Plywood under quartz countertop? kbrinton Remodeling 5 04-11-2008 07:04 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 08:48 PM
