-   -   Kitchen plywood countertop glue? (http://www.diychatroom.com/f5/kitchen-plywood-countertop-glue-47332/)
ohman 06-23-2009 06:51 PM
Dear all, sort of new here, how are you doing?
We have a old kitchen countertop that I believe is made of plywood. The countertop was covered by a layer or thingy that I don't know what it is. See photos here:
http://yfrog.com/0jkitchencoutertoplargej
Recently on the edges that layer is starting to peel off. I wonder what would be the best glue possible to glue this back (with short set time of course, as the peeling layer has the resistance to come off, and for this corner area I can't find a really heavy stuff to put on top of it)? Should I be using Epoxy glue? Thoughts or comments? Thanks!
jerryh3 06-23-2009 07:16 PM
Contact cement.
MinConst 06-23-2009 07:53 PM
Yes contact cement. Try to carefully lift this loose section and clean under it the best you can first. You can use paint thinner. Put contact cement on both pieces (laminate and substrate. and allow to become dry to the touch then put the two together and press tightly.
Floorwizard 06-23-2009 08:18 PM
perfect instructions.....
good job....
anyone else find it funny they put a seam there?
Maintenance 6 06-24-2009 07:16 AM
After the loose piece is glued back together, all the inside corners should be caulked to prevent water or spills from getting into the joints.
ohman 06-24-2009 01:52 PM
Thanks all! You guys are the best! :thumbup:
