Old 07-02-2009, 02:52 PM   #1
Budding DIYer
Default Kitchen flooring -- from vinyl to ceramic tile (or...?)
We'd like to replace the kitchen flooring in our kitchen, built in 2002. It's the original vinyl, and it is torn in a few places and just generally worn out. I'd like to put ceramic tile in there, but I'm open to other suggestions. We have nice oak flooring in the entryway and then carpet in the dining room, which are the two adjoining rooms.
The first problem I see is that the vinyl flooring extends underneath the cabinetry. How would I rectify the cabinet heights and/or remove the vinyl when putting in ceramic? I understand from reading a few threads on here that I would not want to remove the cabinets and then reinstall due to probable damage occurring in the process. Could I take out the appliances (underneath the range and fridge, too), take out the toe kicks, tile what I need, then replace? How would that affect the dishwasher with the countertop?
The second problem I've deduced from reading here is the subfloor. I gather I would need to put down something like Hardibacker over the subfloor. How big of a job is that? Also, if part of the floor is somewhat buckled (board underneath is sagging a bit), I would have to tear out that board, replace, then install the Hardibacker, right? Any other things to consider with regard to the subfloor?
Next, we want to do the countertops as well (laminate to granite), but would it be better to do the floor first and then the countertops or vice versa?
Lastly, how much would such an installation cost for a professional installer? I realize that there are regional variations, and it depends on the cost of the tile; however, what's a ballpark for lower grade tile? This isn't our "forever home", but the upgrade would be nice while we have it. Plus, it'll help resale since most of the homes in our neighborhood, judging from listings we've seen, have the original flooring. We're in northern Maryland, if that matters for the pricing.
Be gentle -- my first post here.
AndrewR is offline   Reply With Quote
More On This Topic
I’m Lee, I have a degree in architecture and about ten years experience in the construction field. Today we have been installing a designer counter top and we’re ready to grout it. You just want to buy the grout color of your choice- we’... Read More »
I’m Lee; I have a degree in architecture, about ten years experience in the construction field, and today we’re installing a designer countertop. Now we want the mortar on a countertop to be mixed thicker than on a floor. On a floor, you want... Read More »
Alright, now we’re going to cover the tile options that there are for your countertops, your bathrooms, on the counters, in your showers, anywhere you wanna put tile. There’s a number of different options. The mosaics, which are beautiful... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. Now in this segment, I am going to be showing you how to set your tile and applying the mud to the floor. We would let our mud slack off after mixing it for 10 minutes. I have a... Read More »
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 42 04-27-2009 11:23 PM
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 8 02-04-2009 01:25 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 08:12 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 07:15 PM
New construction + vinyl kitchen removal pburgh Flooring 5 03-25-2006 04:53 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
