Kitchen flooring help
I installed 3/4" hardwoods in the living room and dining room a year ago. My wife now wants the same thing in the kitchen. I ripped up the linoleum in the kitchen. The sub-floor is 1/4" lower than the hardwoods in the dining room. It has two layers of plywood with 3/4" under 1/2". If I remove the 1/2" layer before installing the hardwoods it will keep the floors even. My problem is that the 1/2" top layer of plywood is under the cabinets as well. Is there a way of cutting the 1/2" plywood close enough to the cabinets so that it can be taken up without removing the cabinets? TIA
