Old 07-03-2006, 05:54 PM   #1
kitchen floor/underfloor heating
I am looking to help my parents redo a kitchen floor and add under floor heating. Looking at either floating laminate or ceramic tile (parents inclined toward lam, I’m inclined toward tile). I’m confused about several things.
1) I’m worried about the life time of laminate especially since the main entrance is through the kitchen and this is a winter climate so snow will inevitably be tracked through. Also, realistically, cost constraints will force this to be a lower to lower middle end laminate. Are my fears misplaced?
2) Most under floor heating systems I’ve seen have pipes/tubing put down and then an inch or two of concrete. I’d like to build up the floor as little as possible, so as not to terribly mismatch with adjacent floors. I’ve found a couple of places online that sell systems that you attach from beneath, basically run tubing between the joists, staple in aluminum sheets around the tubing to the bottom of the sub floor, and then insulate. Looks really simple (I have easy access, 2/3 of kitchen over unfinished basement, 1/3 crawlspace), but I’ve had several people tell me they don’t think such a system will work well without the thermal mass of the concrete. My instinct is that it will since a couple of uninsulated hot water lines under the bathroom, right in front the sink, seem to have serendipitously created a nice warm floor (so wonderful ). Of course working doesn’t necessarily equal efficiency or even good idea. I should also mention parents want base board radiators removed for aesthetic reasons, so floor hearing system must actually be able to heat the kitchen.
3) I’ve heard several warning not to use electric floor heating with laminates. Presumably the concern is the heat drying out the lam making it shrink? Why would water heating be any better in this regard (or is it just less popular)?
LanterDan is offline   Reply With Quote
Old 07-03-2006, 05:58 PM   #2
Oh, for what it is worth, the floor is approx 17'x10' (make 17'x13' or so if you want to count area underneath cabinets).
Old 07-04-2006, 08:17 PM   #3
Floorwizard's Avatar
I live in AK, and I would recoment tile if you plan on tracking in snow and not wanting to worry about it.
Floorwizard is offline   Reply With Quote
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 10:45 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 08:13 PM
