Old 03-04-2006, 10:15 AM   #1
XI LOVE U X
helenfromtheblock's Avatar
Send a message via MSN to helenfromtheblock Send a message via Yahoo to helenfromtheblock
Exclamation
kitchen floor tiles HELP!!
Hi my kitchen has floor tiles but i dont like the colour, i would like black ones instead i have been told that the tiles that i already have are going to be very hard to take out, could i tile over the origional ones?
helenfromtheblock is offline   Reply With Quote
Old 03-04-2006, 07:57 PM   #2
Floorwizard's Avatar
if it is ceramic tiles, the you will need to remove them.
expensive decision, but it's possible.
you may be able to install over the top, but I would not take the chance.
ceramic tiles right?
Floorwizard is offline   Reply With Quote
Old 03-04-2006, 09:53 PM   #3
747
registered
747's Avatar
Those tiles will not be hard to take out. Go to the equipment rent a center in your area. Rent a air hammer. Take the air hammer start it on the grout line then angle it under the tile. I guarantee you all that tile will come up no problem. My rent a center had the electric air hammers which was nice. You will have those tiles up in probably 2 hours. Depending on the size of your kitchen.
747 is offline   Reply With Quote
Old 03-05-2006, 07:05 AM   #4
What type of subfloor are they over, wood, with a mud job or CBU, or over a concrete slab?
I doubt you'll be ready for new tile in 2 hrs., if over wood subfloor, the layer under the tile will have to come up as well if damaged from removing the tile and the thinset too.
R&D Tile is offline   Reply With Quote
Old 03-05-2006, 07:44 AM   #5
XI LOVE U X
Hi guys thanks for replying, to be honest im not sure whats underneath the tiles and yes i think they are ceramic and they seem pretty solid. I did get told it would be a very hard job and messy lol. how much would it cost to hire that electric thing? dont think id be able to do it myself lol we'd prob have to get someone in to do it for us so it will prob be an expensive job as well huh
Old 03-05-2006, 03:10 PM   #6
747
registered
747's Avatar
It depends on your area how much it will cost to rent a air hammer. Shouldn't be over 80 dollars for the day. I guarantee you its worth it. Those tiles will come up no problem. Teeter will even tell you that. Just call up and ask. Ask if they have a electric airhammer you can rent. Most places rent by 4 hours or the day. Well thats the way mine is. Just make sure your going at a angle once you get it started under the tiles. You just want to get under the tiles. Like i said the grout line is the place to start straight down then angle quick to get under the tile. You can do it yourself. No problem Don't you have a son or husband to help or boyfriend?
Ps AIR CHISEL HAMMER. ELECTRIC
Old 03-05-2006, 05:12 PM   #7
Home Improvement Guy
ron schenker's Avatar
To find out what your subfloor is just remove a heat register and have a look under there. You should be able to see what it is.
ron schenker is offline   Reply With Quote
Old 03-05-2006, 07:02 PM   #8
Is this a slab or wood floor?, doesn't matter exactly whats under the tile if a wood floor, if it's not on a concrete slab, it will be harder to remove the tile without damaging what's under them, and if CBU was used and applied correctly, a pry bar and alot of back breaking work is ahead.
Old 03-05-2006, 09:21 PM   #9
747
registered
747's Avatar
He is correct if you don't rent a air chisel hammer.
Ps. Where is teetor at? Tell her teetor. Oh wait a minute teetor saves his airhammer for the detail work..LOL
Old 03-06-2006, 04:42 AM   #10
XI LOVE U X
Im in uk by the way.....what on earth is a heat register? Yeah i have a partner but hes got no diy experience and not too sure if my 2 yr old son could help lol.
Old 03-08-2006, 10:47 PM   #11
A heat register is the little tin, wood, or plastic grill in the floor where the air blows out from.
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 08:13 PM
