Old 05-16-2009, 02:27 PM   #1
Kitchen floor - granite or porcelain?
Hi,
I am refitting my small domestic kitchen and want to lay a floor that's not too expensive but hard wearing. The 7 sq mtr floor will be laid onto a concrete base. I am torn between granite and porcelain but cannot decide which as I want a plain black (or nearest to), glossy finish, and a tile approx size 400 x 400mm or bigger. I have to work out the wastage on these sizes but would like to know if there is a preference in which type of tile to go for first.
Many thanks.
Miqs79 is offline   Reply With Quote
Old 05-16-2009, 02:52 PM   #2
Super Moderator
Floorwizard's Avatar
Porcelain is more affordable.
Ceramic does well too and is more affordable than Porcelain.
Your on the right track with tile, just make sure it's installed correctly and your good to go.
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 05-16-2009, 02:58 PM   #3
Thanks for that. I decided on Granite or Porcelain because it is more hard wearing than Ceramic. Which in your view is best - Granite or Porcelain please?
Old 05-16-2009, 03:20 PM   #4
Originally Posted by fast1 View Post
any budget?
Yes ..... within reason! I particularly wanted a tile that has no vein or texture. Just plain black - or at least very dark grey. I have seen tiles so far in the UK ranging from £25.00 to £60.00 per sq mtr plus delivery which is the same from £25.00 to £60.00 depending on amount. Obviously I am not needing a great amount so I guess I shall have to a premium on delivery. I just wanted your views on the aesthetics and practicality of either of these types. I just want it to look good and STAY that way! Here's hoping.
Old 05-16-2009, 06:10 PM   #5
Super Moderator
Granite is more valuable and expensive
Porcelain is darn tough too....and still valuable...
Just plain black
Hard to find and not used often because it shows EVERYTHING!
Black absolute for granite will work...
Time to ride again!
More On This Topic
Now we’re going to talk a little bit about the recycled products. The terrazzo type countertop material is usually a ¼ inch, you can even order it thicker than the ¼ inch, ½ inch, and it does have to have underlayment so it doesn... Read More »
How to Trim Tile
How to Trim Tile by eHow.com
Applying tile to a room can add interest as well as accentuate architectural details. Choosing the right tile for trim is very important and can add the proper finishing touch that makes or breaks a project. Read this article to learn more. Read More »
Porcelain floor tiles are harder than ceramic tiles and durable beyond compare. The problem is that they're also quite hard to drill through and cut. To drill through porcelain floor tiles, you have to use a diamond drill bit. Read More »
In this clip I'm going to introduce you to the project, and summarize the steps that we take. After a recent kitchen renovation your builder stock white outlet cover and switch plates are going to stand out against your beautiful tile that you have... Read More »
Alright, now we’re going to cover the tile options that there are for your countertops, your bathrooms, on the counters, in your showers, anywhere you wanna put tile. There’s a number of different options. The mosaics, which are beautiful... Read More »
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 10:19 AM
Kitchen underlayment questions for porcelain eis61374 Flooring 9 11-14-2008 01:24 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
