Kitchen backsplash and baywindow combo
DensGuard or DensShield (either one is fine) are carried by the home centers in my area--with some variation from store to store. HardiBacker, Durock, or PermaBase are also acceptable but harder to work with.
I've not worked with OmniGrip so I really can't say. With the right substrate it would likely be fine.
If I were installing your tile, I would use a premium modified thinset. Yes, I recommend you prime your wall repairs.
As an alternative--have you considered a stone slab for the bottom of the bay? (granite, quartz, etc.) Most granite fabricators have lots of remnant pieces laying around their shop and you could likely get one at a very reasonable cost.
Christopher Wright, WrightWorks, LLC
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
