Kerdi Basement Shower - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2009, 01:04 PM   #1
Rewards Points: 14
Basement Kerdi Shower
Hi all,
I'm in the process of putting a 33"x33" shower stall in the basement. Currently I have framed the walls and covered them with green board, and I have been looking more and more at this Kerdi system.
My plan is to make a mud bed right on top of the existing concrete, and cover everything with the Kerdi fabric, and slope it all to drain properly.
Has anyone ever used this method WITHOUT using the Kerdi drain kit? I realize it is recommended to use the kit, since it provides a 4 inch overlap into the drain.
But at a $100 for the drain alone, this system is not cheap! I was thinking about using a traditional 2" ABS drain, and running the fabric overtop of that.
Basically the same way as the old method with a rubber line, except using the Kerdi fabric.
Any thoughts/ideas/suggestions???
Thanks!
ldogg is offline   Reply With Quote
Old 09-13-2009, 01:39 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
THANK YOU.
What you propose is not a industry-sanctioned method.
No real way to seal the KERDI to the "traditional drain" as you call it. What about the necessary lip for the tile making it flush with the drain top?
There is no way to bury the KERDI and isolate the walls with the KERDI at the same time if that's what you are thinking.
XXX
Old 09-13-2009, 02:14 PM   #3
Rewards Points: 14
Originally Posted by Bud Cline View Post
THANK YOU.
Ok - Thanks for the info.
My method would require to slope the base slightly for the drain after the Kerdi has been applied, therefore it sounds like this is no good.
What it sounds like your saying is I should go for the Kerdi drain and follow the instructions accordingly?
I'm not sure if there is any way around this, however I would rather do it properly and not have to deal with any leaks or issues in the future.
Old 09-13-2009, 02:46 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That would be my suggestion.
There are a few sound methods available to you but jury-rigging something when it comes to water is always a costly mistake.
By the time you do what you are suggesting, that $100 drain won't sound so expensive.
Now, tell me where you are finding the KERDI Floor Drain for $100, I can't buy them that cheap. And I buy several a year.
XXX
Old 09-13-2009, 05:42 PM   #5
Rewards Points: 14
Home Depot sells the drain kit alone for $99 in southern Ontario.
Old 09-13-2009, 06:02 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Son-of-a-gun!!!
I pay about $118 for the basic S/S drain on line straight from Schluter.
XXX
Old 09-13-2009, 06:03 PM   #7
Rewards Points: 14
Next question...
One other thing I was wondering about...
Do you think I still require to built a traditional mud pan on the existing concrete pad with the vinyl liner?
I was thinking I wouldn't need the liner since it is directly on concrete, and the liner is generally used to protect a wooden floor on an upper level house?
Ultimately, if the whole shower is being covered with Kerdi then it should be water tight anyway... Correct?
Old 09-13-2009, 08:28 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The requirement is to have a sloping floor. The gradient is to be not less than 1/4" of slope per foot of run.
If you don't cast a second layer of concrete the KERDI Drain won't have a place to go. The base of the drain requires some subsurface room. You could dig out the existing concrete to accommodate the drain I suppose.
The "liner" is to collect and channel the water, protecting a wooden structure is a result of collecting and channeling the water.
I guess I'm confused. You don't need a liner AND the KERDI. Only one is needed.
XXX
Can I install Kerdi over primed drywall in a basement bathroom? Mechelle Tiling, ceramics, marble 13 04-22-2012 10:50 AM
Basement Shower Drain Gas Smell ThunderCAT Plumbing 10 07-30-2009 02:04 AM
Basement shower install howto greight Building & Construction 4 04-13-2009 04:19 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
