Keeping All Rooms Connected With Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 05:55 PM   #1
keeping all rooms connected with laminate
So I'm installing a laminate floor for a client on the entire top floor, and I'm trying to keep all of the rooms connected together. Along the hallway there is a section where approx. 6 rows will continue from the front of the house all the way to the back, leaving those rows about 50 feet long. I know it will look great like this, but I heard the other day that I should separate one room with a transition or the rows will separate over time. Is this true or can I get away with keeping everything connected?
krangksh is offline   Reply With Quote
Old 03-31-2012, 10:01 AM   #2
Rewards Points: 1,574
Anything in the mfg's instructions on this issue? I'd start there.
I've about 30' of Armstrong's wood click and fold or some such with no issues at 3 yrs but maybe I'm lucky.
bob22 is offline   Reply With Quote
Old 03-31-2012, 10:31 AM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
I have installed hole apartment floors, bedrooms and all in one lay. Some people will tell you that you need a transition under the doors but I think that's just the easy way out then to make your cuts under the jams which can be done if you know how. Make shore your lines are staggered 12" apart and you have your 1/4" gaps.
JetSwet is offline   Reply With Quote
Tags
laminate , separate
removing wall, can I patch laminate floor to connect 2 laminate floors? tworicks Building & Construction 2 01-21-2012 06:47 PM
Hardwood vs Laminate Yuri23 Flooring 15 10-30-2011 03:55 PM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 06:05 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
