Just How Perfect Does My Subfloor Have To Be For Hardwood? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 10:46 PM   #1
just how perfect does my subfloor have to be for hardwood?
I'm laying 3/4" T & G and I plan on laying 3/4" prefinished hardwood on top.
My house was built in 1905 so... I have a bit of "out of squareness"
I've never done subflooring or hardwood, so I was wondering how big/small of a gap can I leave in between the walls & subfloor?
Not that I will intentionally, but with the lack of squareness and one really interesting wall, I know I'm probably going to be a bit off at some edges.
Is there any sort of wood filler or putty I should look at getting to correct any major flaws of mine?
Thanks in advance
graysqwrl is offline   Reply With Quote
Old 08-09-2011, 06:00 AM   #2
DIY staff
Rewards Points: 7,174
3/4" nailed down hardwood will bridge 16"----In the old days hardwood flooring was nailed to 1x2 sleepers space 16" on centers----this allowed the electrician to run conduit between the subfloor and the hardwood.
If you have some gaps,you will be fine.
Old 08-09-2011, 06:07 AM   #3
AfterDinnerDIY.com
I personally wouldn't worry to much about squareness. Most of the time, squareness problems occur at a wall/floor joint. Most people do not walk on the floor next to a wall. make sure that you lay the hardwood across the floor joists as opposed to parallel to the floor joists.
AfterDinner is offline   Reply With Quote
Perfect Cut Crown LOUSY CARPENTER Carpentry 4 11-04-2010 12:33 PM
Perfect Ceiling Edging? Creekbender Painting 5 11-02-2009 09:26 PM
Perfect stain mix for dark chocolate brown floor finbriar Flooring 2 04-14-2009 06:19 AM
The perfect brown - is there one? mischka222 Painting 12 01-24-2007 08:13 AM
