09-12-2009, 08:07 AM
#1
Just bought a house with Travertine floors. Can the marble be refinished? Cost?
I just bought a nice clean house built in 98 but had Travertine floors put in 2006. The floors are in beautiful shape now but the thing is I will be renting it out to my sister and my little nephews. I am pretty much resigned to the fact that the floors are going to get stained and scratched all to hell in the next few years. My question is, when they move out how much am I looking at to refinish about 1600 square feet of the marble? And can refinishing really erase most stains and scratches, bringing it to it's former beauty?
Also the Travertine looks polished, does it still need to be sealed? If so can you recommend a great sealer, especially for the money?
09-12-2009, 02:32 PM
#2
Tileguy
It should definitely be sealed NOW. Preferably (in this case) USING A COMMERCIAL STONE SEALER and then adding a few sacrificial applications of floor wax that can be renewed or stripped later.
As far as "what sealer" and "how much" it will cost...these are questions you must ask a local floor maintenance person. Call around your area and get some quotes and recommendations.
Yes, it can be refinished later but removing deep stains if it isn't sealed now may be very difficult.
09-13-2009, 06:44 PM
#3
Thanks for the input Bud. I plan on sealing it next weekend. They start moving in on the on the 27th or 28th. I think I will also take your advice and wax it too. Is there a certain amount of time you have to let the sealer cure before you wax it?
09-13-2009, 07:41 PM
#4
Tileguy
No real "set time" but the preceding applications must be thoroughly dry.
The wax must be compatible with the sealer.
09-13-2009, 09:31 PM
#5
Civil Engineer
You mentioned that you have travertine floors, then later you asked how to seal the marble. Travertine and marble are different stone, and require different sealant. You need to determine first of all whether you have travertine or marble, then you can decide what type of sealant to use. Certain travertine varieties are very soft, and are very difficult to seal, whereas most marble varieties are harder and somewhat easier to seal.
09-13-2009, 10:34 PM
#6
Tileguy
The makers of stone floor sealers would disagree.
09-14-2009, 04:25 AM
#7
Sorry when I googled Travertine, I kept seeing the reference "Travertine marble". The stone is supposed to be Travertine, at least that was what was stated in the MLS before I bought it. I have only been in the house twice, I really have no idea what it really is other than it's a very nice looking polished tile floor. Seems like an expensive add-on for a 250k house(that don't get you much in most parts of California).
09-14-2009, 07:54 AM
#8
Also, and on top of finding out if it is marble or travertine, find out if it has a honed or polished finish because that may indicate whether sealing is even possible. One is like a mirror and one like satin...
09-14-2009, 09:33 AM
#9
Tileguy
Doesn't matter in this case.  It will take a sealer to some degree. Depends on what has been done to it in the past. Toe-may-toe, toe-mah-toe.
09-14-2009, 08:37 PM
#10
"Doesn't matter in this case"
Yeah, I agree it doesn't matter...because in this case, if the poster claims it is polished travertine, then nothing will stain it anyhow making any sealer application redundant.
And the point made about different stones requiring different sealers is interesting; don't know if I'd go that far but it is true that different chemical technologies apply to some stones better than others. Some sealers have a technology that is more for lower absorbency stones, like the marbles and some sealers are more for granites with higher absorbencies...
And to top it off, 'travertine' is sold by itself or sold as a "marble" but it's sometimes called a "limestone", isn't it...?
09-14-2009, 09:08 PM
#11
Tileguy
Problem is trusting the process. Polished stone should have tighter pores simply because the finish is more refined and therefore theoretically tighter. Prior to polishing, sealers and waxes are sometimes applied to the stone, not always. You can't rely on that having been done. All stones can be stained to some degree if the right liquid is applied to it and left to penetrate.
Sealers ARE NOT stain-proofers. Sealers are maintenance aides, meaning they will allow one the time needed to clean up a spill. Most of today's sealers are also "vapor transmissive". What does that tell you?
Agreed.
Some sealers have a technology that is more for lower absorbency stones,...like the marbles and some sealers are more for granites with higher absorbencies...
There is some truth to that. But it is just the opposite. Marble is much much softer than granite and therefore more at risk. Granite (real granite) is very dense and would in most cases require a sealer of very low viscosity. Granites such as "Absolute Black" are so dense they won't take any kind of a sealer.
We are talking penetrating sealers. Then there are the topical sealers that produce a coating and are intended to stay on the surface.
It may be called limestone by those that don't know, but limestone is a different animal all together.
09-15-2009, 08:15 AM
#12
"Granite (real granite) is very dense and would in most cases require a sealer of very high viscosity"
Bud, you bring up a question: what relation do you perceive there to be in your experience, between viscosity of a sealer and its applicability?
09-15-2009, 09:38 AM
#13
Tileguy
Thanks for drawing my attention to my error. I couldn't think of another word to convey what I was trying to say and then I blew it.....
I should have said:
"Granite (real granite) is very dense and would in most cases require a sealer of very low viscosity"
09-15-2009, 10:27 AM
#14
OK that makes sense...I think of 'viscosity' as "thickness" of a solution. A consomme soup versus a cream soup; 99-cent shampoo versus Pantene. Measured with reference to water at room temperature which is something like 72 dynes/cm sq. Some of the better surface active agents can get down to 27 dynes/cm sq - and these are used in sealers.
Is this what you are referring to, Bud, water-based vs solvent-based?
09-15-2009, 07:15 PM
#15
stop it - you guys're making my hair hurt polished surfaces don't need sealers IF they're well polished (home depot floors're ' honed ' meaning the process has gotten prostituted from what was originally spec'd ( there's always someone who can do it cheaper ),,, waxes're sacrificial protection + providing ' grip ',,, travertine ( or fill'd marble ) has had german cement applied to fill the natural fissures that God left in the marble.
when my bride, nagzilla, express'd her wish for fancy granite c-tops, it was interesting to hear the specialist (salesman) say we'd have to SEAL the granite occasionally,,, reinforced my belief few one used good stone anymore as the prices're high & consumers balk,,, we made cemetery monuments which're sometimes polished,,, 100yrs later, my grandfather's work's finishes're still good while great-GREAT-grandfather's could use some repolishing,,, remind me to tell him
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
