Old 04-10-2005, 02:57 PM   #1
Default Joining skirting boards in corners
I am tiring to put new pine torus skirting boards in my room but really struggling with cutting the wood to create a 45 degree angle for the corners. Does anyone have any advise on the best way to do this?
kiwitart is offline   Reply With Quote
Old 08-18-2005, 12:19 PM   #2
Unfortunately when two walls meet the angle is rarely exactly 90 degrees!
First of all you need to have a device for cutting wood at an angle, B&Q do a cheap one that you operate by hand, you can select quite a few angles and the saw blade is fine enough not to damage ssmaller pieces of wood.
The easy option is to by a compound mitre saw, again B&Q are knocking these out cheap at the moment for £30-40.
Anyway you'll have to read the instructions on their operation, the important bit is finding out what angle exists between yor walls, you can either buy an angle finder, screw two bits of straight wood together or use trial and error.
I prefer trial and error as its quicker, get two offcuts of the skirting (not too long) and cut one at 45 degrees this represents one length of the skirting, then cut the other at 45 degrees but the other way round. These should join nicely in your hands to form a corner, put them against the actual corner and see if any gaps appear when both pieces are flush against the wall.
If you get a gap at the front then your wall must be more than 90 degrees, simply get another offcut and increase the cutting angle on your machine to 46 degrees and keep doing this until you get a good match at the wall, remember what angle worked with the offcuts and cut your skirting.
All the best
nicknackynoo is offline   Reply With Quote
Old 08-20-2005, 11:33 PM   #3
Link to another post. this may also be of help.
http://discussdiy.com/showthread.php...id=516#post516
Mgmopar
MgMopar is offline   Reply With Quote
Old 02-14-2007, 04:57 PM   #4
You need to scribe internal corners and mitre external corners.
This might help-
Fitting skirting boards
alfy is offline   Reply With Quote
More On This Topic
So we’re working on our outside corner piece here. We’ve got our first piece done. It fits in just like that and you can see now why it is important to measure it from the back of your piece. We would have measured from the front of our piece... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
Circular Saw Angle Cuts
Circular Saw Angle Cuts by Expert Village
In this we're going to talk a little bit about some of the angles that you're going to be cutting with your, with your circular saw. Again, when we're making adjustments we're unplugged. We just did a forty-five degree cut didn't we so now if you look... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will be showing you how to layout our back and cut it. While I'm waiting for my last piece of trim to dry I'm going to start laying out my back support piece. For the support of the back... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we are going to demonstrate how to cut base moulding on an outside corner. By outside corner, I mean that you have a wall right here and this is the outside corner that you are going... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
