Jim F. A Finish Carpenter - Flooring - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 12:15 PM   #1
Jim F. a Finish Carpenter
I am a finish carpenter going to be installing my 1st. hardwood floor, In a large loft type room. no matter what wall i start with, there is a partition wall in the middle of the space that comes into the room 4',I have an idea about how to start the floor in this situation,( by working off of a chalk line) but I am not sure. Is there a better way to insure that when I get both sides past the partition wall that they will still interlock together ??????????????
JimFalz is offline   Reply With Quote
Old 07-24-2010, 12:47 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
"interlock"? Is this a hardwood or floating laminate?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-24-2010, 03:22 PM   #3
DIY staff
Rewards Points: 7,174
post a picture or a sketch of the layout if you can---someone here will offer a suggestion
Old 07-24-2010, 04:49 PM   #4
Attached a Crude Diagram
I hope that my crude drawing attachment comes thru for you & that you can help me with my situation. No matter what wall I choose for a starter wall I have a partitan wall to deal with. Thanks JimFalz
Old 07-24-2010, 06:03 PM   #5
DIY staff
Start in the middle-(at the partition)-use a spline so that you are tongue out in both directions---then head towards the wall--that should eliminate the problem of getting the different areas to meet evenly.
JimFalz (07-24-2010)
Old 07-24-2010, 08:41 PM   #6
Thank you I think I understand, But can you elaborate a little more.......Thanks Jim F.
Old 07-25-2010, 05:33 AM   #7
DIY staff
A spline is a thin strip of wood that is used to join two boards---back to back.
This allows you to change the direction that you are nailing.
By starting that room in the middle (at the partitions) and nailing the floor in both directions,you have eliminated the problem of trying to start on either side of a wall and hoping that the floor boards end up perfectly aligned with each other.
----Mike----
BigJim (07-25-2010)
Old 07-25-2010, 03:18 PM   #8
Jim a Finish Carpenter
Mike, Thank you for all your help,the advice is priceless....... Jim
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
