Jambsaw/Undercut Saw For 8" Baseboard - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 04:08 PM   #1
Rewards Points: 459
Jambsaw/Undercut Saw for 8" Baseboard
I'm considering purchasing a Roberts 10-55 Jamb Saw.
I'll be installing carpet (mostly) and some tile throughout my house over the next couple of years. I'd like to do so over the existing hardwood, without removing all of the baseboard. The baseboard is painted 1 x 8 pine.
Two questions:
1) Is it feasible to undercut 1/2" in a fairly neat fashion (at least that a low nap carpet would hide?
2) In a very small application (4' x 6' foyer), is it feasible to install the tile under the existing baseboard once it is trimmed?
Nick DIY is offline   Reply With Quote
Old 12-08-2010, 08:24 PM   #2
i asked a similar question of a local finish carpenter, and was told It would mess up the baseboard trim. in addition, if you ever want to go back to the hardwood floor, you will have the cut to worry about.
what about using some 1/4 round at the bottom?
1910NE is offline   Reply With Quote
Old 12-08-2010, 10:30 PM   #3
Two questions:
I would not attempt either of these. simply lay your new floor then attach 3 quarter round trim to your 1x 8 pine.
warnerww is offline   Reply With Quote
Old 12-09-2010, 12:01 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The carpet doesn't necessarily have to go under the baseboard. Any semi-talented carpet installer can make it work.
You NEVER want to install any ceramic tile over any hardwood flooring.
XXX
Old 12-09-2010, 12:37 AM   #5
I am not a big remodel guy. I have built a few new homes for myself but very little remodel experience. Why can't you put cement board over existing hardwood flooring then tile over that???? I have never done it but in my mind I can not find a problem with it. If I am wrong ( which is entirely possible) please help me learn I am always willing to listen and learn.
Old 12-09-2010, 08:36 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Because...hardwood flooring is in fact unstable (believe it or not) when it comes to covering it with a rigid ceramic tile installation. It moves slightly in all directions with seasonal changes, atmospheric changes, yada yada, and such but as a hardwood floor the movement goes unnoticed. Place a hard rigid tile floor over it and you can be asking for serious trouble.
...in my mind I can not find a problem with it
Where else have you looked?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
tpolk (12-09-2010)
Old 12-09-2010, 09:23 AM   #7
Rewards Points: 459
My biggest concern here is time.
I don't want to incur the extra time of mitering, installing and finishing shoe molding through the majority of this house. Nor do I like the look of it.
My hope is that with a steady hand, I could set the guide on this saw to 3/4" and make a straight-enough cut for the carpet to hide. Use the multi-tool to catch the ISCs that the saw can't hit and tuck under.
There is currently 1/4 round installed to the hardwood. If I pull that and tuck the carpet between the tack and base, I'm afraid that the old paint line will show. I do not want to refinish this baseboard (which is also why I don't want to pull the base & reset it).
Has anybody tried to use one of these saws to do as I described?
As far as the tile job, I'll definitely be looking for more advice on these details in an upcoming post.
Thanks all for your input.
Old 12-09-2010, 09:38 AM   #8
Rewards Points: 200
If you don't have the time to do it right now , When will you ?
Quote from a wise old man.
We install cpt with the base flush to the floor all the time . What is the problem ?
Floor Doc is offline   Reply With Quote
Old 12-09-2010, 09:50 AM   #9
The older I get the better I was
Old 12-09-2010, 09:58 AM   #10
Rewards Points: 459
This is the problem.
And if trimming the base would work, It would be "doing it right". That's what I'm trying to determine.
Old 12-09-2010, 12:02 PM   #11
Rewards Points: 200
Is it a true 1/4" 1/4 rnd ?
Are you installing pad under the cpt ?
Old 12-09-2010, 12:16 PM   #12
Rewards Points: 459
Floor Doc,
It's a 3/4" high quarter round. Yes pad under the carpet. I was thinking on trimming out 3/4" from the bottom of the base, right across the paint line. I know this will be high, but I may also consider a longer nap carpet to hide that. I appreciate any advice!
Old 12-09-2010, 12:25 PM   #13
Rewards Points: 200
1] You don't want to leave the 1/4 rnd down . Makes a much nicer looking job when the cpt goes to the wall.
2] Use 1/" 8 to 10LB rebond pad . that leaves you with only 1/4" to cover with the cpt .
Hope this helps .
Old 12-09-2010, 12:29 PM   #14
Rewards Points: 459
Thanks, Doc!
So you think the Jamb Saw would do a well-enough job undercutting 3/4" off the baseboard, then?
Old 12-09-2010, 02:24 PM   #15
Rewards Points: 200
Still don't know why you want to cut the baseboard . There is no need for it .
The Jam saw is for door jams . If i were going to rip the base , i would take it off and run it through the table saw .
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
