Isolation Membrane On Plywood - Flooring - DIY Chatroom Home Improvement Forum
Old 11-06-2008, 11:02 PM   #1
Rewards Points: 150
isolation membrane on plywood
is it necessary to use an isolation membrane over a plywood subfloor in a bathroom porcelain tile installation?
drewhart is offline   Reply With Quote
Old 11-07-2008, 06:47 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It isn't necessary but it's highly recommended. I never like to install ceramic directly onto any wooden substrate. I've seen too many problems as a result.
poppameth is offline   Reply With Quote
Old 11-08-2008, 09:10 PM   #3
Get out of the box!
Rewards Points: 260
Use Ditra, it works as isolation and uncoupling membrane.
Nac Tac makes a good isolater.
I would suggest installing ceramic over wood with Ditra or a CBU.
26yrsinflooring is offline   Reply With Quote
Old 11-08-2008, 10:40 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 218
I agree. Installing tile direct to a wooden subfloor, (has to be double layer), can work, but is not recommended by any pro that knows his/her business. It should never be done where dampness can occur, such as a bathroom. I also recommend either a tile backer or Ditra. Ditra is my first choice, use it if you may get it in the amount you need?
Jaz
JazMan is online now   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 06:16 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
