Integrating New Hardwood With Old - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 10:19 AM   #1
Integrating new hardwood with old
8 years ago we installed 3/4" tongue and groove hardwood throughout our downstairs, except for the kitchen. We now want to extend the hardwood into the kitchen and the easiest way would be to put a threshold between the two sections of floor. (the floor runs perpendicular to where the threshold would be)
However, we don't want that visual separation since the two rooms are completely open to each other. Any tips on removing some of the older planks and sliding the new ones in tp soften the transition?
Artwench is offline   Reply With Quote
Old 02-24-2008, 01:55 PM   #2
You will need to cut a "relief" groove down the middle of one of the boards that you want to remove. Then you work this board out from the tongue and groove and the rest should be removed the opposite way as when they were installed.
redline is offline   Reply With Quote
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
How to tell what hardwood... evane Flooring 9 09-06-2007 01:42 PM
