Intalling Engineered Hardwood Over Partical Board - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 10:22 AM   #1
Intalling Engineered hardwood over partical board
can you install egineered hardwood over partical board? If yes what precautions should you take?
cmclean is offline   Reply With Quote
Old 11-04-2010, 03:56 PM   #2
Hey Cmclean,
I am Gregg with The Home Depot in Chicago. I have a few questions about your project. Do you currently have particle board as a subfloor or do plan on putting it down? If you do have particle board as a subfloor do you know why? Particle board isn’t especially strong and is probably not a very good surface to install nice new hardwood on. Let me know more about the project. –Gregg
gotogregg is offline   Reply With Quote
Old 11-04-2010, 05:50 PM   #3
There need to be some definitio of what You are calling particle board . 1 True particle board looks like fine sawdust on a very smooth sheet .2 OSB oriented strand board is sometimes thought to be particle board , OSB is large flakes of sawdust ,Sometimes 1 inch or two inch and you can feel the roughnes on one or both sides , , Definetly not fine sawdust , Particle board would never be layed as the sub floor ,Unless some one made a huge mistake , It has no structural strength rating and would sag between joist of it were installed as subfloor. So I will assume you mean particle board layed over the sub floor in a litchen or laundry , Where there was vynil ,
The answer is .YES you can lay floating engineered over particle board , But particl board will not hold a nail down product for long
tacomahardwoodfloors.com
tacomahardwood. is offline   Reply With Quote
Old 11-04-2010, 06:40 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Are you in a mobile home? Particle board was used for years as subfloor in mobile homes.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
hardwood on top of particle board troutman Flooring 8 01-26-2011 04:05 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 09:45 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
3/4" Partical board underlayment OK for new 3/4" oak? housefixin Flooring 4 02-23-2008 05:36 PM
