Insulayment Question - Flooring - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 06:09 PM   #1
Rewards Points: 173
Insulayment question
Dear experts,
I am installing hardwood floor. My sub-floor is plywood. I purchased "insulayment" to go under the hardwood floor. My question is simple: should/can I staple the underlayment to the plywood? Or I must glue it? I wood prefer to avoid it: it seems that the underlayment under the hardwood that will be nailed to the plywood will have no way to go anyway. Still, I would like to ask you what is the right thing to do.
Thanks,
Dmitriy
dpreznik is offline   Reply With Quote
Old 08-28-2011, 07:26 PM   #2
Rewards Points: 200
MP Global Products | Insulayment Underlayment
Follow the manufacture directions .
Floor Doc is offline   Reply With Quote
Old 08-28-2011, 07:46 PM   #3
Rewards Points: 173
Thank you for your answer. I have read the directions. But on the picture there I can see that the underlayment is glued to the plywood, and then the hardwood floor is glued to the underlayment. But I am going to nail the hardwood floor, so I don't understand why one would need to glue the underlayment. Also, the instruction doesn't state that it is the only way, or what glue should be used.
Thanks,
Dmitriy
Old 08-28-2011, 07:54 PM   #4
Rewards Points: 200
If you are nailing you don't need to glue it . I would use a foil tape for the seems though . duct tape is ok , but not as good as foil .
The Following User Says Thank You to Floor Doc For This Useful Post:
dpreznik (08-28-2011)
Old 08-28-2011, 08:55 PM   #5
Rewards Points: 173
May I ask what the tape is for?
Old 08-28-2011, 10:04 PM   #6
Rewards Points: 200
MVE Moisture Vapor Emissions , and to hold the seams together .
dpreznik (08-29-2011)
Old 08-29-2011, 06:25 AM   #7
Rewards Points: 173
Does it matter what side of the underlayment goes to the top, and what side goes to the bottom?
And if one decides to use glue, what glue should it be?
Thanks.
Old 08-29-2011, 06:47 AM   #8
Rewards Points: 200
Logo facing up .
This is a good pad for a floating floor . For a nail down i would use either a 15lb felt [tar paper]. or Aqua bar B .
Old 08-29-2011, 08:34 AM   #9
Rewards Points: 173
Logo facing up .
Hmm, I don't see any logo...
Old 08-29-2011, 09:04 AM   #10
Rewards Points: 200
Is this what you have ?
Old 08-29-2011, 10:00 AM   #11
Rewards Points: 173
No, I don't have anything blue. It looks like on the picture here:
http://www.quietwalk.com/insulayment/index.html
on both sides. Just one side is little bit smoother.
Old 08-29-2011, 10:33 AM   #12
Rewards Points: 200
One side should be smoother then the other . put the smooth side up .
What are you actually nailing to the floor 3/4" ?
you still need to get the floor flat , and take rh , temp, and mc readings .
Old 08-29-2011, 10:52 AM   #13
Rewards Points: 173
Yes, 3/4". I don't understand what it means to take rh , temp, and mc reading?
Is it important to have the smooth side up? Sorry for the silly question, but the people in Lamber Liquidators where I bought the product told me it didn't matter, so I already cut it in wrong way
Old 08-29-2011, 11:58 AM   #14
Rewards Points: 200
Why am i not surprised at the info you got at LL.
The smooth side is the barrier .
MC = moisture content
RH = Relative Humidity
Temp = temperature of the house .
They all have to jive for the wood to be acclimated . for 2 1/4" wide the wood has to be within 4% MC of the substrate . 3" and wider 2% at a certain temp and RH .
Time has nothing to do with acclimation . If the house is not acclimated the wood can set there for a year and still not be acclimated .
Old 08-31-2011, 07:39 AM   #15
Rewards Points: 173
One more question: I read in another thread of the forum that insulayment may be a bad idea in general for a nailed hardwood floor, because nails would not hold well having that soft stuff between plywood and the floor. Do you have any information if this is true? Because if it is so, I would not use it at all, though I have already spent $100 on it.
Thanks.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
