Old 03-05-2010, 03:04 PM   #1
Insulation
When building a floor on top of a cement slab, can the insulation lay directly on the cement or does it need to be suspended in the air?
debd is offline   Reply With Quote
Old 03-08-2010, 08:38 PM   #2
Insulation
What type of floor and what type of insulation?
Laminate floors can go over concrete with a vapor barrier and good insulation/ cushion made for laminate floors- normally no thicker than 3/16".
If you are building a full floor with 12" joists or tgi's and a 3/4" plywood or OSB subfloor over them 24-36" of airspace is required and the airspace should be ventilated. Your local building codes and where you live have a little to do with it as well.
AKFloorguy is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General Discussion 5 11-08-2010 11:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
