Insulating A Floor Above An Unheated Crawl Space - Flooring - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 05:49 PM   #1
Insulating a floor above an unheated crawl space
I am about to install a new engineeered floor over a plywood subfloor in my den. Currently it has thick padding and wall to wall carpeting. I am afraid that once i take up the padding and the carpeting and install the new wood floor the floor will be very cold in the winter. There is insulation under the floor from the crawl space side now. I was thinking of using the pink 2 x 8 sheets of insulation board on top of the sub floor, then installing a 1/4 ply wood and then install the new floor. Is this the right thing to do?
Joe Vassallo is offline   Reply With Quote
Old 09-04-2010, 06:33 PM   #2
Rewards Points: 1,512
I think the pink foam boards will squish here and there over time and the floor will then either sag (if the squishes are large) or squeak (if the squishes are small.
Any way you can add more insulation to the underside? Use "unfaced" batt insulation because you do not want a vapor barrier down that far and you don't want a second vapor barrier if you properly have one at the subfloor..
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
Insulating split level home crawl space. sithappens Building & Construction 1 02-29-2008 09:47 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
