Old 03-08-2008, 09:28 PM   #1
insulating concrete
I am going to pour a concrete floor for my garage and plan on putting pex in it for heat. My question is should I insulate my pad & or footer? If so with what and where to put it? I dont want the most energy effecient garage ever but I do want it to stay heated.
deere2440 is offline   Reply With Quote
Old 03-08-2008, 10:57 PM   #2
insulating concrete
i would suggest insulating under the slab and up the inside of the wall to the height of where your studs will start... you want to visulize you heat not being able to get out of the concrete...i used 2 inch styrofoam...some use only bubble wrap..i guess go with what you can afford..but my choice was more is better
billie_t is offline   Reply With Quote
Old 03-09-2008, 07:47 AM   #3
insulating concrete
If I pour the footer first could I just insulate under the pad & between the pad & the footer? Along with up the inside.
Old 03-09-2008, 08:37 AM   #4
insulating concrete
you can do what you like, remember heat does not just rise..when you think radiant..think..heat goes to cold.. your heat will travel through your cement in any and all directions..where ever it does not run into insulation, ,will be heat loss, so you want as much "heat loss" directed into your living space as possable and the least amount of "heat loss" anywhere else
insulate the floor as best you can...think of your insulation as a big bowl holding your heat...if there is a crack anywhere you have a little leakage..the bigger the crack the faster the leakage and the faster you have to add heat to keep the bowl full
leaks cost fuel..fuel costs money...there may be times you have to live with a little leak or two...keep them as small as possable
Old 03-09-2008, 12:36 PM   #5
concretemasonry's Avatar
insulating concrete
Insulate under the interior floating slab with EXTRUDED polystyrene with some strength and not EXPANDED polystyrene (the beadboard that is only used for coffee cups, etc.).
You could insert a thin (1/2" to 1") extruded polystyrene layer between the slab and the stem wall. If you are pouring a structural slab instead of a interior floating slab, you just have to accept the heat loss out the edges of the slab to exterior.
concretemasonry is offline   Reply With Quote
Old 03-09-2008, 12:59 PM   #6
ICF Construction
insulating concrete
Product called Warmedge for the slabs edge and foam below
Personally I don't like foam below a garage floor, they still make a tinfoil bubble product I know most guys will thrash on but in a garage I would rather use that and use foam in the basement.
Chris
Chris Johnson is offline   Reply With Quote
Old 03-09-2008, 02:11 PM   #7
insulating concrete
My thoughts were to dig a 12" wide 30" deep footer and pour it first. Then come back and place my insulation, pex & pour the slab. Im just worried that if it is all one piece that the footer will settle and crack the slab.
Old 03-09-2008, 09:33 PM   #8
ICF Construction
insulating concrete
If the footing settles you have bigger worries than a cracked slab...it is a major structural defect!!!
Chris
Old 03-09-2008, 09:41 PM   #9
insulating concrete
I just mean 1/2 inch or so over many years time. I was told by a local contractor that if I pour it all at once that this is a concern. He said if I was to do it all at once I need to cut a break point just inside the walls all the way around the building or it could settle and break the floor in the middle. I figure it is easier to just pour the footer and let it cure then pour the floor inside of it so that it is a seperate piece all together.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Insulating Joists over concrete sandyman720 Building & Construction 5 05-24-2007 01:52 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
