Insulating - Flooring - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 11:10 AM   #1
insulating
i have a home that has no sill plate the floor joists are sitting on the concret wall. I like to know what the best way to insulate it would be. i was told to use foam spray to seal any gaps and put up faced insulation and another way was just to put up faced insulation. i have no moister or rot problems.
The other problem i have are that i have three basement windows that there are two foor joist sitting on top of them and the frame windows are made of metal. They are starting to rust through. i would like to replace them with a better window.
Thank you
Cliff
amsa is offline   Reply With Quote
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
