Old 07-02-2009, 01:37 PM   #1
Default Installing wood floors over saltillo tile
Has anyone installed engineered wood floors over tile, specifically saltillo tile or have an opinion on this type of installation? The tile is solidly adhered to a sub-floor, and would require some leveling. If this has been done successfully by anyone, what was the procedure?
Bloom is offline   Reply With Quote
Old 07-02-2009, 02:18 PM   #2
Tool Geek
PaliBob's Avatar
You can get a nice flat surface by using one of the self-leveling floor resurfacers e.g.
http://www.reedconstructiondata.com/...or-resurfacers
I see two concerns:
  1. Because of all the Saltillo irregularities you may end up with a topping that is in some places one inch thick.
  2. What does your Engineered floor manufacturer say about installing over concrete?
Disclaimer
& Stay Safe
.....Bob
Old 07-02-2009, 07:32 PM   #3
I haven't selected the wood flooring yet, so I'm not aware of their recommendations. The installer also recommended planing the tile first to get rid of the high places, although, I'm not sure how this is done.
Old 07-03-2009, 12:42 AM   #4
Tileguy
WOW!!! Good luck with that concept.
I assume you realize if the tile stays the wood will have to be glued to install it. Someone should check to see that the adhesive will (in fact) be compatible with the modified substrate. Adhering wood to raw Saltillo or even SLC may be an issue. I don't know for sure but someone should be asking someone before you go ahead with this.
My personal vote is to remove the tile and get that substrate back down to where it should be. To keep heaping floor covering atop floor covering is never a good idea.
Tags
engineered wood floor, tile floor
More On This Topic
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
Installing new vinyl flooring is an inexpensive way to improve the look of a room, especially kitchens, bathrooms and laundry rooms. You can save quite a bit of money by installing the vinyl floor yourself. The most difficult step is applying the... Read More »
Substrates for Tile Mosaic
Substrates for Tile Mosaic by Expert Village
Right now we're going to talk about substrates. Substrates is just a fancy word for what you glue your tiles to. Today I've chosen this little mirror for us to use. I liked it, it was a good first project because it's small and it's also got a mirror... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. Now in this segment, I am going to be showing you how to set your tile and applying the mud to the floor. We would let our mud slack off after mixing it for 10 minutes. I have a... Read More »
My name is Paige and today we are talking about the best way to clean your wood floors. There are several steps to cleaning your wood floors. What you want to do first is vacuum; sweep your baseboards on your wood floors picking up all the particles that... Read More »
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 05:10 AM
Tile vs Wood as a baseboard MattCoops Flooring 12 05-27-2009 05:39 PM
Wood floors gapping gpj111 Flooring 21 05-12-2009 05:33 PM
Please help with wood floors?!? Pilly Flooring 0 06-17-2008 03:06 PM
Tile Walls - Wood Floors - which goes first? MikeinBurien Flooring 1 03-04-2006 08:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
