Old 11-28-2010, 09:03 PM   #1
Installing wonderboard on pier and beam foundation
I just finished putting wonderboard down on a plywood floor with pier and beam foundation and noticed that there is still some squeaks in the floor when you walk across it. Should I be concerned? If so, how do I fix before I lay the tile?
Harrington is offline   Reply With Quote
Old 11-28-2010, 09:44 PM   #2
Did the floor squeak before the wonderboard was laid? The wonderboard is not meant to remove squeaks.
Did you put thinset under the wonderboard before you screwed it to the subfloor?
bob22 is offline   Reply With Quote
Old 12-01-2010, 07:15 AM   #3
Yes, the floor squeaked before I put the wonderboard down. I put thin set underneath it and attached with appropriate screws every 6 inches. I assumed that the wonderboard would build such a strong foundation for the tile that any squeaks would be eliminated in the wood below, but it doesn't sound like that's the case, correct?
Old 12-01-2010, 01:29 PM   #4
Tileguy
JazMan's Avatar
Harrington,
Unfortunately you thought wrong. Concrete boards may make the floor seem stiffer, but it adds no structural strength and neither has anything to do with squeaks. Squeaks mean the boards are loose and need to be fixed before you install the concrete backer. You can still fix this from underneath....maybe.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Pier and Beam - Buckling Sub-floor - Need Advice dmanindfw Flooring 3 06-14-2010 06:27 PM
Bathroom subfloor pier and beam foundation Etomli Tiling, ceramics, marble 8 05-21-2010 03:38 PM
Pier and Beam foundation, 1925 house NewOldHomeOwner Building & Construction 8 01-30-2010 12:51 PM
Pier & beam foundation JustEnuf Carpentry 2 08-02-2009 08:58 PM
Concrete piers for post & beam foundation jpecor Building & Construction 1 08-01-2008 01:27 PM
