Installing Travertine Floor Tiles - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 10:09 PM   #16
Obviously You need a floor first, then set ditra. Go to ditra web page and do your homework, read specs, and you will see.
I use it several times in different structures it work every time, but read instructions and type of setting.
EHouse is offline   Reply With Quote
Old 06-14-2011, 11:07 PM   #17
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 130
Uh, Bud and Jaz are actual tile installation experts. I'm not, but even I know that Ditra will not cure all ills.
(I have installed ceramic a number of times , but don't consider myself an expert.)
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-15-2011, 07:42 AM   #18
...Sorry about my older post, did mean to say "forget everything", I meant, you can also use.
I am just trying to bring up a good alternative or supplement that nobody mention, you guys are right about everything I read too. And if you don't secure the subfloor I will crack anyways.
Take a look on crack isolation membranes installation ANSI A108.17
I am not expert but I only lay down tiles for six years, hundreds of ceramic, porcelain , stone and glass jobs, for a tile store company, different procedures, lots of problems, repairs, lot of field experience, I learn a little about that and other little reading ANSI installation standards books.
Tags
flooring , thinset thichness , tiles , travetine
Proper Way to Attach Travertine to Brick... 99altrade Building & Construction 16 12-08-2010 07:56 PM
travertine flooring on concrete subfloor robismyname Flooring 2 09-17-2010 08:12 PM
Can I put hardwoods on top of existing travertine? jmwinke Flooring 11 11-22-2009 01:33 AM
travertine floors Keith Carlson Ceramic Flooring 4 09-29-2008 11:41 PM
