Installing Transitions For Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 02:31 PM   #1
installing transitions for hardwood
Need to install transitions on my new hardwood between the wood and tile. I left my expansion gap of 3/4" between the tile and wood, but now reading the instructions for transition installation, it says I should have left a gap of 1 1/4" between my tile and hardwood so there is space for the bottom piece of the T molding transition. How do I fix this problem? Should I try and cut 1/2" off the edge of my hardwood? This seems like it would be very difficult to do. Or can I trim off the bottom peg of the T molding strip and nail the strip down? Or would the molding be OK to just install in the 3/4" gap? I also have this problem along the door jams for the front door, and the first step of my stairs.
Thanks in advance for any help!
cmlcsu is offline   Reply With Quote
Old 12-17-2009, 02:44 PM   #2
I've got a question on the same topic, but no answer yet:
Tiling entryway - proper transition for this scenario?
(Not trying to hijack your thread - just sharing the same issue)
Scott99999 is offline   Reply With Quote
Old 12-18-2009, 11:33 AM   #3
Rewards Points: 14
Im assuming your transition strip is similar to the attached document. If so the reason they recommend a 1.25" gap is so the hardwood can move with the changing humidity (same reason you leave gaps around the perimeter of the rooms) you have 2 options
1.) Rip off the 0.75" x 0.75" "tounge" and attach the strip to the hardwood only Wood glue or construction adhesive with finish nails works well.
2.) Increase your gap to the recommended 1.25" by cutting the hardwood floor (it doesn't have to be pretty because it will be covered by the transition strip) and attaching to either the subfloor with glue and nails or to the hardwood only.
The reason for attaching to only the subfloor or the hardwood only, not both, is to allow movement as stated above.
rohman is offline   Reply With Quote
Old 12-19-2009, 10:56 AM   #4
Thanks for the reply, I think I will rip the 3/4" tongue off the molding then glue the molding to the wood. It just sounds easier, and i am ready to have this project finished.
Installing DWV system new construction joebart Plumbing 2 01-29-2009 08:45 AM
Installing Hardwood questions myphaykename Flooring 10 01-23-2009 09:48 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
