Installing Tile Floor In Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 09:49 AM   #1
Rewards Points: 12
Installing tile floor in kitchen
Hi, I am remodeling my kitchen which has sheet vinyl on it currently and I want to install 18x18 porcelain tile. I have been told to install 1/2plywood and then 1/4" hardibacker cement board over that as a sound foundation due to the size of the tile. Does this sound correct? Any suggestions on the best way to remove the old flooring?
kapry13 is offline   Reply With Quote
Old 03-20-2013, 10:22 AM   #2
Rewards Points: 13,732
Need to first figure out if that floor will support tile.
What's the joist width, unsupported span, subflooring make up, and spacing?
Is there 1/4 plywood under that flooring now?
Old 03-20-2013, 10:26 AM   #3
I did tile floor in my kitchen which previously had vinyl. I used 16x16 tiles and aside from what was under the vinyl, typical plywood/osb subfloor, I put down ditra uncoupling membrane and then the tile.
bova80 is offline   Reply With Quote
New kitchen floor going in, deciding on a backboard/underlay for ceramic tile efciem Tiling, ceramics, marble 10 03-08-2012 08:26 PM
Porcelain tile kitchen floor - Getting started joemontana16 Flooring 61 01-29-2012 08:50 PM
Covering Kitchen Wall Tile ryanb4614 Tiling, ceramics, marble 6 12-03-2011 10:34 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Tile floor replacement in kitchen ol rick Tiling, ceramics, marble 1 12-30-2009 12:17 PM
