Installing Swiftlock Plus Floating Laminate Wood Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 09:21 PM   #1
Installing Swiftlock Plus Floating Laminate wood floor?
Hello , Hubby will be installing this floor this weekend in our dining room. Upon ripping up our carpet we have found the particle board subfloor has areas of wood sticking up, piles of glue and various other issues with not being perfectly flat. How do we go about making sure the floor is flat enough? Also the floor we bought has the foam backing already on it, is there any benefit to putting down any additional foam or will this just cause more problems? Also hubby took all the moldings off around the room and tells me he doesn't need any spacers around the room because there is room under where the molding was removed for the floor to expand, does this sound right to you? Also any additional tips you can give us to assure a good outcome of this product would be appreciated. Thanks!
bixa525 is offline   Reply With Quote
Old 07-12-2009, 09:39 PM   #2
Can anyone please help?
Old 07-13-2009, 12:37 AM   #3
Particle board subfloor? Is it 1/4 inch particle board over the sub floor? If so just rip it up and replace it so you have a nice smooth surface to work with.
G17GUY is offline   Reply With Quote
Old 07-13-2009, 08:20 PM   #4
Hubby says it is 5/8" or 3/4" OSB tongue and groove subflooring and it is glued and nailed down. Should we just sand it as smooth as we can get it?
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 05:06 PM
Installing laminate flooring in basement, staples in floor Catalina76 Flooring 5 09-14-2008 01:56 PM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 10:06 AM
