Installing Subfloor - Edges Not Hitting Joists - Flooring - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 09:39 AM   #1
Installing subfloor - edges not hitting joists
Installing attic subfloor. Truss bottom chords are 24" oc but some are not too accurate. My 4x8 subflooring is missing some of the "joists" by 1/2" or so. What is an acceptable way to fix this? Can I sister 2x6s to the bottom chords of the trusses?
novaguy is offline   Reply With Quote
Old 12-11-2012, 09:54 AM   #2
Rewards Points: 13,282
Before going to far with this are you even sure the trusses are rated for top loading?
Is this going to now be a conditioned area? (HVAC)
By adding plywood your cutting way down on the avalible space for insulation.
To ansewer your question, yes you can sister some 2 X 6's.
Old 12-11-2012, 10:07 AM   #3
Thanks. These are attic trusses rated for 40 psf LL. the attic space will be conditioned. Do i need to sister the 2x6 the entire length of the truss (from wall to wall) or can i add it just where i need it in the center section of the truss?
Old 12-11-2012, 02:29 PM   #4
Called truss mfg. He says I can use a 2x4, just where I need it, nailed to the 2x6 truss with 1 16d nail per foot.
Old 12-11-2012, 05:00 PM   #5
I'd be using a nail gun not a hammer, unless you want to do some sheetrock repairs.
Harwood in a Galley Kitchen Parallel to the Joists? David Osinga Flooring 8 12-05-2012 06:38 AM
Best way to frame in a lateral bracing between joists miamicuse Building & Construction 2 03-19-2012 11:08 PM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 08:28 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 09:50 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
