Installing Stair Treads. - Flooring - DIY Chatroom Home Improvement Forum
Old 05-19-2008, 09:51 AM   #1
installing stair treads.
Just got done installing Bamboo flooring and am getting ready to do stairs. I ordered full treads and risers, and was wondering if you can just put the new treads and risers over the existing ones.
Wild Duk is offline   Reply With Quote
Old 05-20-2008, 08:41 AM   #2
You will change a lot of things by doing this. IMO, R&R is the best way to go.
mark942 is offline   Reply With Quote
Old 05-20-2008, 09:23 AM   #3
Rewards Points: 12
I'm getting ready to do something similar. I plan to order full stair treads for each step. Since my stairs are boxed in on both sides, the installation should be relatively simple. I'll start by cutting the nose off of each step with a reciprocating saw. Apply a lot of glue to each step and use a few nails to hold the tread in place while the glue dries. I'm planning on using 1/2" MDF for the risers because they'll be painted. I'll let you know how it goes.
mpt1123 is offline   Reply With Quote
Old 05-20-2008, 09:34 AM   #4
47_47's Avatar
Rewards Points: 58
Just a caution mpt1123, you will increase your first step and decrease your top step heights by the thickness of your new tread. I believe that the maximum rise variation cannot be more then 3/16".
47_47 is offline   Reply With Quote
Old 05-20-2008, 09:56 AM   #5
Rewards Points: 12
I'm installing a 3/4" hardwood flooring stair nose to the top step - with hardwood throughout the hallway. That should solve the top step issue. Still thinking about the bottom step.
Question on installing pergo stair nose amaruenterprise Carpentry 11 10-11-2009 05:21 PM
Stair Treads Melanie337 Flooring 1 04-01-2008 11:22 PM
Scribe Cutting Oak Stair Treads kcdave Carpentry 2 03-18-2008 07:13 PM
Installing floating engineered hardwood in entrance and stair stringers bluedisc22 Flooring 3 01-25-2008 02:03 PM
Cracked Stair Treads pickel011 General DIY Discussions 1 12-27-2006 03:31 PM
