Installing Snap Together Flooring Over Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 12:43 PM   #1
installing snap together flooring over linoleum
hey guys. ive done many types of flooring so my best friend wants me to come over and put together this snap together floor over linoleum kitchen floor quick and cheap .......so does the linoleum act as the moisture barrier, so that all i need to put down under the new flooring is the foam underlayment?? ........also a small portion of the subfloor is rotted. he cant afford to replace it and wants to know a solution because this is an old house and its not worth ivesting much money in. maybe a leveling filler designed for this??.............I know its not the propper way to do it but hes on a tight budget and wants to rig it in order to save money. the subfloor isnt rotted halfway through yet. should i just fill it the best way i can with scrap material or is there a better filler solution for this?
Sponseller is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
Question about installing new vinyl flooring nschulz Flooring 2 06-18-2011 02:19 PM
Help installing allure flooring trafficmaster yukon tan bill14019 Flooring 4 02-11-2010 11:33 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Question about linoleum flooring JZ2008 Flooring 2 02-24-2008 07:59 PM
