Installing Slate Title To Outdoor Cement - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 04:00 PM   #31
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Based on everything I've read and learned from you, I've decided to go with porcelain so that 3/16 in cantilever should be stronger anyway (right?).
The porcelain is a better choice and is a lot stronger than the slate for sure. In the past I have cantilevered those type of joints a helluva lot more than 3/16". I wouldn't worry about it if it was mine.
Old 07-14-2009, 07:20 PM   #32
Hmmmm. Please clarify for me guys. Are you saying the cantilever idea is ok with slate, but not porcelain? I had concluded it was safer with porcelain.... Also, please note this area of the porch is seldom walked upon. In fact almost all of the porch us not walked upon, except for the area in front of the door.
Thanks,
Steve (not stevie).
S. Stansbery is offline   Reply With Quote
Old 07-14-2009, 09:07 PM   #33
Tileguy
Bud Cline's Avatar
Rewards Points: 558
And I thought we were On-A-Roll!
Steve, either will work just fine, porcelain is way tuffer than slate.
Exactly my assumption all along, it's a typical porch.
Old 07-15-2009, 10:55 AM   #34
Bud, Once again...thanks very much! This is perfect.
Steve
Old 07-16-2009, 03:54 PM   #35
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I thought we were well past that point. Did I skip some pages or what?
Old 07-16-2009, 09:11 PM   #36
Tile on Porch Project
Bud, no..you didn't skip anything. Before I ask my last stupid questions, let me say thanks once more. Your advice has been fantastic.
Ok, I'm posting a photo of the porch, with the tiles layed out (somewhat). My questions are:
Question 1- Considering that the porch is not square (why would it be?) at 57 3/4 on one end (the far end) and 57 1/4 on the near end, should I lay my tiles using the format in the photo (from the front edge back to the house - full tile on the front edge with tiles to be cut against the house), or should I lay the tiles "from the house" out to the front edge of the porch (like my dear wife believes I should). My wife's logic is, since you have to make so many cuts around the posts, why not make the the front edge the one with the short tiles and then have all full tiles against the house.
Question 2 - If I do lay the tile from the house out to the edge, and I don't plan to use bull nose, can I sand the corners of the tile to eliminate the sharp edge.
Question 3 - am I just fooling myself by not using bull nose?
Queston 4 (and final) - should I lay the vertical tiles on the face / front of the porch first, or last?
Thanks again!!!!
Steve
installing Slate title to outdoor cement-dscn8373.jpg   installing Slate title to outdoor cement-dscn8374.jpg
Old 07-16-2009, 09:37 PM   #37
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I see you are putting a lot of thought into this, that's a good deal.
Here's what I would do.
I would definitely use bullnose. It will do two things for you. It will soften the edge and it will make the cuts around the posts more pleasing because it will help to break up how your eye perceives the overall installation. (Don't know if that makes any sense or not)
I would install the vertical tiles first. This way if the front edge of the porch is slightly off you can fudge the surface tiles (bullnose) just ever so slightly to help to hide any variance while overlapping those vertical tiles. Install the bullnose tiles completely. Then install the field tiles. I would cut to the house, this will hide that variance more or less.
I would do what had to be done to use full bullnose at the corner (start there) and lay it out dry to be sure there were no slivers that would fall around the posts. IF you have to move laterally to avoid a sliver at a post you can do so without drawing attention to the variance. Don't worry about the bullnose tiles hitting at different places in conjunction with the posts that is going to be unavoidable.
I would also try to position the bullnose so that the bullnose joints are swapped with the field tile joints, in both directions. This will separate the men from the boys I'll tell ya. It may not be totally possible but worth a try.
P.S. I would also till that soil around the porch so that it can be moved and compacted easily with your hands. This way it can be mounded where need it to support the vertical tiles overnight while the thinset dries.
Old 07-16-2009, 09:41 PM   #38
Man, you are fantastic! Thank you very much. If you are ever in St. Louis, look me up. I'll buy you dinner!
steve.stansbery@yahoo.com
Old 07-16-2009, 10:02 PM   #39
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Believe it or not, St. Louis is my home town. Born in Granite City when it was a world renowned steel town. Worked on the original I-270 bridge and the Gateway Arch when they were being built. Been on the old Admiral many times when it was an excursion boat. Used to take a train from Union Station in the days it was a real railroad station before it became a menagerie of shops. Worked on Lion Country at the zoo and went to the old Checkerdome when the St. Louis Blues were kings of the ice. Fished the Mississippi as a kid. Yup, I know a little about the old St. Louis area. White Castles and Steak 'n' Shakes. A-h-h-h-h, but I regress.
Old 07-21-2009, 09:04 PM   #40
St. Louis
Just read your post (as we've been fretting and installing and fretting) for the last three days.
Wow! Those were very significant St. Louis projects. Well, the offer stands...if you make it to St. Louis, send me an advance email. Would gladly take you to dinner (not White Castle....but maybe Steak and Shake ...... since my daughter is a server there).
Thought you might like to see photos of the finished product. Not professional by any means, but we are proud of it for a first time effort. I must admit that I didn't take your advice about the bull nose. The tile we bought did not have any bull nose available and my wife and I could not agree on any sort of "accent" color, stye.
Nevertheless, we are very happy about how it turned out, and are very grateful for your tremendous guidance.
FYI, I cut under the posts with my angle grinder, and layed the tile underneath the moulding around them. If I was doing it over, I'd probably go the extra mile and replace the moulding (which is was my doing a few years ago and which I would have destroyed getting off since it's on there with nails and liquid nails and quad and every other darn thing I could think of at the time, to ensure moisture would not get to the posts).
Bud, best wishes to you!
Steve.
PS. THANKS AGAIN!
installing Slate title to outdoor cement-dscn8375.jpg   installing Slate title to outdoor cement-dscn8378.jpg
Old 07-21-2009, 09:38 PM   #41
Rewards Points: 4,534
striking appearance,,, keep the pics to compare in 5 or 10yrs,,, st. louis does freeze.
Old 07-22-2009, 04:14 PM   #42
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Looks pretty darned good to me.
Old 03-28-2010, 09:08 AM   #43
More Slate Questions for Bud
Bud,
GREAT looking slate tile over concrete in that picture. Was that done here in Nebraska?
I too live in Nebraska and want to do something similar on my 20X20 concrete pad. I've been to both HD and Menards asking about either using Slate or natural stone tiles. Frustration set in as I got opposing answers on either type of tile. I was even told I could use Porcelain tile as long as it's "grade" was a 5. I would prefer to use the stone tiles or slate is it looks better.
1. If there are types of slate(as far as where it's from) what do you recomend?
2. Can natural stone tiles be used?
3. I believe you said the quick set morter that Menards sells is the best for our harsh winters to use?
4. What brand/kind of sealer to use when project done, and how often should it be done as a maintenance thing.
Thanks for your help,
Scott Shaeffer
Omaha, NE
sashaeffer is offline   Reply With Quote
Old 03-28-2010, 11:42 AM   #44
Scott, The tile pictured directly above is porcelain and it's in St. Louis Missouri. Not sure if your referring to those pictures or Bud's pictures of his amazing patio job) .
Bud and friends were a GREAT help to me on my project. I knew nothing when I started. I elected to go with porcelain, based on some of Bud's and others' posts, but my neighbors have had slate down for 5 years and no problems, except for some minor delamination.
Bud, thanks again for all the advice almost a year ago. You were a great help!
Steve
Old 03-28-2010, 09:23 PM   #45
Steve,
I had been referring to the picture of the patio that was done by Bud, but I didn't realize that your porch tile was Porcelain. It looks great and it also looks like slate.
Where did you buy the tile?
Scott/Omaha
Slate tile Termite Flooring 14 04-01-2010 10:05 PM
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 05:59 PM
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 08:58 PM
Slate Tile... Jshakour Flooring 13 04-24-2008 11:34 PM
Advice and help on slate floors adamsela Flooring 1 10-04-2006 05:23 PM
