Installing Quality Porceline Tile Over Well Installed Plywood Base - Flooring - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 12:56 AM   #1
Installing Quality Porceline Tile over Well installed plywood base
I have just removed a cermaic tile floor in my Kitchen. The tile was in great condition after 20 years. My intent was to Install Hardy backer and retile with a high quality porecline. When I removed the Cermaic tile floor, I found it was on a solid 3/4 Toung and grouve Subfloor with a 1/4 inch plywood backer very well glued to the subfloora. There was a metal mesh lathing stapled to the backer and what appears to be thin set over the mesh.
Removing the tile floor was a challenge, but the mesh actually helped, because we were able to get a prestine surface under the mesh. There is know way we can remove the backing 1/4" plywood as it is glued and holding well.
I want to go forward with an install of porceline tile over the origional surface. I know nothing about a metal lath layer.
Can I go forward with a Thin set over the existing subfloor and backing materal..
If I need to put down a mesh, what is it and how do I install
lcarlson123 is offline   Reply With Quote
Old 04-12-2013, 04:45 AM   #2
DIY staff
Rewards Points: 7,174
You got lucky on that mesh job----they are not as dependable as Durrock---as a matter of fact the 'Jersey Mud ' job is not recommended at all---
My suggestion ,if the 1/4" ply is glued securely---add 3/8 or 1/2 inch BC ply over the top---then 1/4" Wonderboard or Durrock---set in thinset and properly nailed-----then set your tile---
I do not like Hardibacker---so I don't use it---your choice---
JetSwet (04-14-2013)
lay vinyl tile on patched holes in plywood charotte Flooring 5 10-25-2012 07:59 AM
installing tile over lineoleum or plywood subfloor? luv2remodel Flooring 12 01-30-2012 08:26 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Preparation for installing ceramic tile RMCarner Flooring 15 04-20-2011 07:32 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
