Old 03-22-2009, 08:04 PM   #1
Installing Prefinished Hardwood Flooring Around Kitchen Island
I will be installing a prefinished hardwood floor around the center island in my kitchen. Any hints to make sure that the rows of flooring do not go off line when installing the flooring around the island? The flooring will be running in the same direction as the length of the kitchen island.
bioman is offline   Reply With Quote
Old 03-22-2009, 08:39 PM   #2
Remodeling Contractor
Put a temporary straight edge at the other end of the island, And measure each side as you install new boards against this reference point, adjusting as needed to keep them the same distance.
Old 03-25-2009, 04:30 PM   #3
Hi Bob,
Thanks for the reply. Hope I can find a straight, straight edge that I can keep parallel to the boards at the start of the island.
Bioman
Old 03-25-2009, 05:06 PM   #4
Originally Posted by bioman View Post
Hi Bob,
Bioman
Run a chalk line at both ends to establish straight parallel lines.
Old 03-25-2009, 07:18 PM   #5
Will do.
Bioman
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
Installing Hardwood Flooring selical Flooring 4 10-24-2008 11:45 AM
Prefinished Hardwood Flooring Problem homade82 Flooring 4 11-06-2007 11:39 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
