Installing Plywood As Subfloor In Basement. - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 07:26 PM   #1
Rewards Points: 152
installing plywood as subfloor in basement.
My father wants to install plywood as a subfloor in the basement. I have never seen plywood installed on top of concrete in a basement.
I just want to know if this is a good idea? Are their any problems that might occur from installing plywood as a subfloor?
humberguy is offline   Reply With Quote
Old 05-18-2014, 07:32 PM   #2
Rewards Points: 440
Bad idea. Only way that I would ever consider doing that is if I put two byes on edge in a frame first and then floor on top of that. Ron
ront02769 is online now   Reply With Quote
Old 05-18-2014, 08:07 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Every time I have seen that done, it failed.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-19-2014, 10:11 AM   #4
Rewards Points: 13,750
Only way I would ever do it is if it was over a product such as Dri-Core.
Old 05-19-2014, 11:31 PM   #5
iminaquagmire's Avatar
Rewards Points: 338
You could do it with Platon. Its a dimpled plastic membrane commonly used for foundation waterproofing. Would be essentially the same as dricore panels, but more solidly attached (you'd have to drill and use tapcons). Only reason I see to do this is to use a nail-down solid wood floor which aren't really supposed to be used below grade anyway.
iminaquagmire is offline   Reply With Quote
Old 05-20-2014, 06:56 AM   #6
Rewards Points: 126
Every hole you put in it for tapcons, allows moisture through.
Just because these home improvement shows do it, doesn't mean it's right. A lot of the stuff done on those shows is wrong. I seldom see anyone do floorcovering right on HGTV.
The Following User Says Thank You to rusty baker For This Useful Post:
JazMan (05-20-2014)
Old 05-20-2014, 08:58 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
If you tape down a piece of plastic in a spot you will see for yourself how much moisture migrates through concrete.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 05-20-2014, 09:47 AM   #8
Rewards Points: 338
The idea isn't to have a moisture barrier. Its to have a vapor retarder. The goal with this if the idea is to install a solid wood floor, is simply to slow down the transmission of moisture between the substrate and the wood. It also allows air under the plywood so it doesn't trap moisture and provides a bit of a thermal break from the concrete for a warmer floor. If the OP plans on a floating floor or tile or something else, there are better ways of going about it. Its just one of many methods. And I've never seen this method on a DIY show. You're right though, they seldom get things right.
Old 05-20-2014, 09:58 AM   #9
Rewards Points: 1,298
False
That only tells you if the concrete surface has reached dew point temperature.
SeniorSitizen is offline   Reply With Quote
Old 05-20-2014, 10:10 AM   #10
PoleCat's Avatar
Originally Posted by Fairview View Post
False
If the concrete is at dew point then the entire floor would be damp with condensate from the AIR. By sealing the section of floor with plastic you remove air from the equation. Also any water vapor that is coming from the floor is trapped and builds up to quickly saturate the sealed area and condense into visible moisture.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Installing an ejector pump for basement sink teeb57 Plumbing 4 10-26-2013 10:46 PM
Installing natual stone veneer on concret basement walls js1979 Concrete, Stone & Masonry 6 06-04-2013 09:53 AM
Installing an electrical recepticle on a basement structural support post PittsburghClint Electrical 8 12-18-2011 07:58 PM
Installing radiant heating in a basement and general basement questions... CarlsonRower General DIY Discussions 6 12-09-2011 12:32 AM
