Installing Pergo, Have A Vinyl Underlay Issue - Flooring - DIY Chatroom Home Improvement Forum
Old 06-05-2009, 06:04 PM   #1
Installing pergo, have a vinyl underlay issue
I'm installing pergo throughout my entire 1st floor. The first floor i prepared was carpeted. Below the carpet was plywood subfloor. This room and the kitchen connect. The kitchen, which was stick on vinyl tiles has a 3/8" plywood underlay. Whoever built the kitchen decided to put the underlay throughout the kitchen, and the cabinets are sitting on top of it. There is no way to remove the 3/8" underlay without either:
1. Cutting the 3/8" as flush to the cabinets as possible (which i can't figure out how to do)
2. Removing the cabinets and pulling the whole underlay.
A dremel is the only way I've had success getting anywhere near flush with the cabinets, but its extremely inaccurate and slow going. I was wondering if anyone had a suggestion for how to cut the underlay flush with the cabinets or if removing them from the wall would be the better option.
Thanks in advance,
Jeff
jyffmguy is offline   Reply With Quote
Old 06-06-2009, 05:06 AM   #2
Get out of the box!
Rewards Points: 260
They make a Toe-Kick saw, you can find them in most tool rental shops. it will allow you to cut the floor back then you will only need your Dremel at the corners
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Installing vinyl plank over existing, uneven floor? AKCDIY Flooring 5 11-01-2014 04:48 PM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Installing Ceramic tile: Ditra over Vinyl or rip out and use 5/8 Plywood? ppieda Flooring 2 10-05-2007 11:01 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
