Installing Laminate Snap Together Floating Floor - Lay It Which Way? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 12:41 PM   #1
Rewards Points: 1,016
Installing laminate snap together floating floor - lay it which way?
First time to ever install this stuff - the room is a 12x13 bedroom with a closet at one end, the closet is nearly the width of the room with wide sliding doors - the new flooring will extend into the closet as well.
Does it matter or make it easier which way should I run the flooring - parallel or perpendicular to the closet end of the room?
thx!
Old 06-13-2009, 01:19 PM   #2
Floorwizard's Avatar
A room that size can go either way.
Floorwizard is offline   Reply With Quote
Old 06-13-2009, 10:14 PM   #3
True could go either way but if you ever wanted to continue with like flooring outside of the bedroom then it would make a difference; unless the bedroom is on the end of a hall way.
dknarnd is offline   Reply With Quote
Old 06-14-2009, 04:49 AM   #4
After another read of the instructions I see a note where the manufacturer recommends installation parallel to the primary lighting of the room.
I assume this is to minimize scratches and the like from showing?
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 08:38 AM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-18-2007 12:18 AM
