-   -   Installing laminate snap together floating floor - lay it which way? (http://www.diychatroom.com/f5/installing-laminate-snap-together-floating-floor-lay-way-46528/)
vsheetz 06-13-2009 11:41 AM
First time to ever install this stuff - the room is a 12x13 bedroom with a closet at one end, the closet is nearly the width of the room with wide sliding doors - the new flooring will extend into the closet as well.
Does it matter or make it easier which way should I run the flooring - parallel or perpendicular to the closet end of the room?
thx!
Floorwizard 06-13-2009 12:19 PM
A room that size can go either way.
dknarnd 06-13-2009 09:14 PM
True could go either way but if you ever wanted to continue with like flooring outside of the bedroom then it would make a difference; unless the bedroom is on the end of a hall way.
vsheetz 06-14-2009 03:49 AM
After another read of the instructions I see a note where the manufacturer recommends installation parallel to the primary lighting of the room.
I assume this is to minimize scratches and the like from showing?
