Installing Laminate Flooring Over Wood Laminate Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-11-2006, 01:22 PM   #1
Installing Laminate Flooring over Wood Laminate Floor
Can someone tell me if it is possible to install a laminate floor over a wood laminate floor that is on concrete? I was looking at Wilsonart floor installation guide and it says wood floors on concrete must be removed before installation.
bantammom is offline   Reply With Quote
Old 01-11-2006, 03:52 PM   #2
Floorwizard's Avatar
I wonder how the wood floor is attached to the concrete, but I would agree to stick with manufacturer recommendations.
Floorwizard is offline   Reply With Quote
Old 01-11-2006, 07:05 PM   #3
johnh
is it wood or laminate?
if the flooring down is a laminate and in good shape i don't see why you couldn't put the new one on top of it. especially if it is a floating floor. make sure there isn't a moisture problem.
johnwhowe is offline   Reply With Quote
Old 01-11-2006, 07:44 PM   #4
Floating floors expand and contract.
plus they have some give to it.
too much give to allow another floating floor on top of that one.
It just isn't something that has been tested.
but if you wanna test it out, then let us know how it goes.
Old 01-11-2006, 10:03 PM   #5
Contractor
I have never done this either. I would drill a 1" hole with a hole saw in an inconpicuios area to determine what is there. If the original flooring has a vapor barrier, I would skip that on the floating floor. My thought is to not have the original flooring trapped between 2 vapor barriers. That could lead to rot.
Teetorbilt is offline   Reply With Quote
Old 04-16-2008, 08:01 AM   #6
I Agree with Teetorbilt. you dont wanna have any moisture between, then you get rott and mold witch could lead to health problems
Flooring_Man1000 is offline   Reply With Quote
Old 04-16-2008, 04:27 PM   #7
Rewards Points: 150
Umm, cuz the manufacturor of the product says not to.
mike costello is offline   Reply With Quote
Old 05-27-2011, 03:34 PM   #8
if the existing laminate is the snap together variety it wouldnt take an hour or so to pull it up. i planned to put the laminate i pulled out of my house in the basement but it turned out to be real pergo and all the pieces were glued together. the early laminate had to be glued instead of the snap lock they have nowadays
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Wood floor help/suggestions bigboyjoel Flooring 18 12-31-2008 12:02 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 08:07 AM
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 02:20 PM
Floor spacers when installing laminate floor flybynite Flooring 4 12-04-2006 09:24 PM
